Old 10-18-2011, 06:42 AM
clemclark clemclark is offline
Vehicle: 1999 dodge ram
Trim Level: sport
Color: sport
clemclark is on a distinguished road
Unhappy help with troubleshooting
i have a 99 ram with the 5.9 having trouble with it starts an runs fine but when driving after gets to running temp lose power and slowlys dies and wont start till cool down i notice that the engine light flashes about 60 times b4 staying steady any info would be highly appreiciated could the tranny filter be clogged up
Old 10-18-2011, 11:17 AM
CoreyB's Avatar
CoreyB CoreyB is offline
Vehicle: 2001 Ram
Trim Level: Quad Cab Sport
Color: Blue
CoreyB is on a distinguished road
Engine temp sensor is a possibility, or a clogged fuel filter. Get the code if you can. Rest assured its not the tranny.
Old 10-18-2011, 01:44 PM
Trim Level: sport
Color: sport
Default thanks corey
i finally got my code reader to work im getting 5 codes of p0300 ,p0301,p0302,p0303 and p0171 waiting for ride to part store to get new plugs and cap an rotor hopefully fixes it but if any 1 else has something that it might be if not those causing it your info will be appreciated and will check temp sensor
Old 10-21-2011, 02:48 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Unless someone has added a fuel filter inline , your truck hasn't got a fuel filter, the pump is integral with the filter, a non serviceable item, low fuel pressure at the intake manifold port = fuel pump change. To properly gauge fuel pressure you MUST use a gauge, spraying gas from the port with a small screwdriver does not suffice as a fuel pump test, and these trucks are very sensitive to variences in pressure. I learned this as a very hard lesson. You need to stick your gauge under a wiper and go for a ride,several miles, to test fuel pressure, if you see ANY varience, a fuel pump is called for. The time and money and frustration I put myself through because I didn't do the gauge to wiper thing... STILL makes my blood boil...
Old 10-21-2011, 04:31 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Since it happens after warming up, that tells me it's a Closed Loop issue, meaning the computer is using all sensor inputs. The codes you listed indicate multi-cylinder misfire, and the 0171 means a lean air/fuel mixture has been indicated by an abnormally rich correction factor. Reads right out of the leaking intake plenum gasket playbook. Have fun.
Old 10-21-2011, 12:32 PM
Trim Level: sport
Color: sport
gen1pak that was my first thought but tryed advoiding that one for i know what is involved in that job but after fighting with plugs and those dam sleeves was helpful ran good for a day so now for the fun tearing down the intake
troubleshooting mwljr Electrical 2 03-28-2011 01:31 AM
New guy in search of some troubleshooting help!! chubcityracing 5.7L V8 Specific Topics 8 02-23-2011 11:28 PM
p0443 evap purge control circuit troubleshooting bigiron Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 1 08-26-2010 12:15 PM
HID troubleshooting? silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 7 09-14-2009 12:28 AM
Need help troubleshooting my 2001 3500 diesel. R Tate Cummins Diesel Specific Topics 2 06-17-2009 04:57 PM
