Dodge Ram Decals
Old 10-18-2011, 12:44 PM
Banzai's Avatar
Banzai Banzai is offline
Vehicle: 2009 Ram 1500 4x4
Color: Inferno Red
Rep:64
Banzai will become famous soon enough
Send a message via MSN to Banzai Send a message via Yahoo to Banzai
Default Bleeding/Replacing Brake Fluid?
Hey guys,
how hard is it to bleed and replace the brake fluid on our trucks?? apparently my brake fluid is black and they want 140.00 to do it?
2009 Ram Sport 1500 4x4
22" Black Rhino Traverses | AFE S2 | Magnaflow | Tinted Tails/3rd brake light | BT Catchcan | 6000k HID Fogs | Debadged | Tinted | RhinoLinings Bedliner
Old 10-18-2011, 04:45 PM
Banzai's Avatar
Color: Inferno Red
Rep:64
not one person has any input??
Old 10-18-2011, 05:05 PM
Rep:4206
Not sure about the 4th gens, but shouldn't be any more difficult than on anything else. Seems odd to me that your fluid is black being as your truck is that new but you can do it the old fashioned way with two people, one pumping and holding the brake while the other drains the fluid at the bleeder screw. A friend of mine prefers the gravity bleed method where you just drain the fluid at each wheel and refill as you go. He told me he prefers doing it that way because, in his mind, pumping the brake introduces just as much air into the system as you're trying to get out. I've never tried it but I will say he had one heck of a pedal when he was done. Just make sure you're using the correct brake fluid and keep checking the master cylinder as you go.
Old 10-18-2011, 05:09 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Originally Posted by Banzai View Post
Hey guys,
I'll chime in. First thought would be why this happened. I would check everything out before bothering with replacing/flushing because it will just spoil the new fluid if you don't. Secondly it sounds like they are charging for an hours labor and some fluid. Not totally unfair really. But if you are savvy you can do it yourself. If you pony-up the money be sure the fluid looks perfectly clean when you pick it up. Drive it around and make a bunch of stops and check again. This will transfer some of the line fluid into the M/C so you can see if they simply emptied the M/C and filled it back up vs. actually flushing the whole system.
The gravity bleed way needs no special tools or equipment but takes time.
Open one bleeder valve at a time starting at right rear and go through the normal sequence until clean fluid comes out.
Be sure and don't let the master cylinder get empty.
Good way to stay out of the better half's way for an afternoon if you work it out right.
No real mystery and will be completed same as any other flush in years gone past. I know of zero reasons this does not apply to our Ram's. Here is a link for more details on a typical two person flush.
http://www.automedia.com/Brake_Bleeding/ccr20011001bb/1
2016 3500 Laramie MC: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 10-18-2011, 09:45 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
Under warranty? Looks like all would be covered, just not pads and rotors. Only reason for discolored fluid is contamination. The brake system is sealed and seals are covered.
CAUTION, If you pressure bleed, you stand a chance of knocking the proportioning valve off center, not fun to reset.
I would only gravity bleed without the proper equipment. Be sure to use the PROPER FLUID.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 10-18-2011, 11:26 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2875
start with the brake cylinder furthest from the master cylinder, usually right rear wheel
keep the master cylinder full as you you do it
at this time don't worry about air bubbles
then go to next furthest brake cylinder, usually left rear wheel cylinder, again don't worry about air bubbles
next wheel is usually the right front cylinder, again don't worry about air bubbles
the last one is the drivers front wheel, again don't worry about air bubbles
now you have all clear fluid
then do the regular brake air bleed, using the same pattern
brake fluid is cheap
remove brake fluid rez? spockmckoy LD RAM - General Discussion 2 06-06-2011 10:33 PM
clean brake fluid rez on truck? spockmckoy LD RAM - General Discussion 10 06-06-2011 12:22 PM
Dodge Ram Van Conversion Window Replacement... ramvan2500 Dodge Ram Vans 4 05-24-2011 11:32 PM
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
brake fluid leaking bad! npoe25 5.9L V8 Specific Topics 6 06-19-2010 03:18 PM
