Old 10-18-2011, 06:55 PM
nickwendl nickwendl is offline
Vehicle: 2001 dodge ram 1500 5.2L V8
Color: green
nickwendl is on a distinguished road
Default need help asap no spark
hey i ve a 2001 ram 5.2L V8 4x4 sat for a few mounths but i started it about once a week. had a few rough starts then nothing. i have replaced coil, cap, rotor pickup coil and about to do crankshaft position sensor which is gonna be a bitch from what i can see. any tips or tricks? any other ideas what the problem could be its driving me nuts and i need to get this truck on the road. please help me out here
Old 10-20-2011, 11:42 AM
CoreyB's Avatar
CoreyB CoreyB is offline
Vehicle: 2001 Ram
Trim Level: Quad Cab Sport
Color: Blue
CoreyB is on a distinguished road
With the key on, verify you actually have power to the coil. Also check for power to the crankshaft sensor, and you can test its output to verify it is outputting its pulse signal. I am unsure of the values you should read, but if you have a manual you can find out.
EDIT. I did a little research for you. You may want to check the Automatic Shutdown Relay, it is in the fuse box under the hood, it supply's power to the coil and to the injectors. Also the values for the camshaft sensor, which is located in the distributor, 3 wires, 1 is sensor ground, 1 is 5v in, and one should be a 5 volts out pulse signal. This should get you started on troubleshooting your spark issue.
Old 10-21-2011, 01:24 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
If I were you, I'd reboot the computer before going after the crank sensor, sure can't hurt .
8 spark plugs vs. 16 spark plugs Basic Corpse Newbie Checkin! 16 01-04-2011 10:23 PM
Spark Plug Analysis?? MOPAR stallion 5.9L V8 Specific Topics 15 12-05-2010 06:24 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
spark plug remove moparmike07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 06-04-2010 11:54 PM
The Spark Plug Difference ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 03-27-2010 09:59 PM
