Dodge Ram Decals
Old 10-18-2011, 07:49 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
Default Changing transmission fluid?????
I am going to be changing the tranny fluid myself, is there any thing i need to know that will help. Also how much fluid do i need to refill it and what is the best. thanks
Old 10-18-2011, 09:06 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
For a drain/ filter change/ refill takes between 7-9 quarts. Just buy 9 or 10 and return what you dont use.
You have 2 filters in there. A flat filter for the sump, and a spin on for the cooler. Make sure to change the gaskets on both, and make sure they are seated correctly or your truck will stall when moving at low RPM. Be careful when removing gaskets and cleaning old gasket material off of pan as this transmission is aluminum. Dont believe the "cold" markings on the dip stick. It will say full cold, but you are actually a quart or so low, drive it and check it hot and forget there is even cold markings. Have fun, and lots of oil dry or rags as there is no drain plug on the pans.
Sure it'll suck, but it'll make you a man
Old 10-18-2011, 09:32 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Where is the spin on filter didn't know there was two filters
Old 10-19-2011, 01:00 PM
440Magnum 440Magnum is offline
Vehicle: 2008 Ram 1500
Trim Level: Lone Star
Rep:26
440Magnum is on a distinguished road
Both filters are inside the sump, as shown in this photo blatantly stolen from a thread on the NAGCA formus :-)
Old 10-19-2011, 01:07 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
This may help you:
http://www.ramforumz.com/showthread.php?t=92056
Sean
Old 10-19-2011, 01:26 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Thanks guys so much very helpful
Old 10-19-2011, 01:57 PM
lifeofchaos13's Avatar
lifeofchaos13 lifeofchaos13 is offline
Vehicle: 2004
Trim Level: Sport Quad Cab
Color: Blue with Racing Stripe
lifeofchaos13 is on a distinguished road
Great info im planning on doing this myself very soon.
545RFE transmission service step by step snrusnak Dodge Ram Knowledge Base 47 09-24-2016 11:50 AM
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 08:38 PM
Transmission Fluid Change Jack772 5.7L (345 cu in) HEMI V8 Specific Topics 24 02-07-2014 01:41 PM
Changing the Transmission Fluid on my 5.9 Jon89 5.9L V8 Specific Topics 12 11-07-2010 02:10 PM
Very Odd Transmission Fluid Issue mck89 4.7L PowerTech V8 Specific Topics 4 06-08-2010 11:36 PM
