Dodge Ram Decals
Old 10-18-2011, 07:52 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
Default 4x4 problem. need fixed tomorrow! please
ok so here it is. my 4 wheel drive hasnt worked in a while and wasnt worried about it cuz thers a while till snow and i have a tractor if i need to get anywhere in the woods or on my farm. my dumb luck i got that stuck today so i gotta fix my truck to pull it out now. transfer case seems ok and shifter feels good but when i shift into 4 high it doesnt work and my dash light doesnt even go on. any ideas would be great. was told maybe the vaccum motor on the front axle but i kno nothing about it or where to get it.
Old 10-18-2011, 08:53 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
The vaccine could be the problem. It basically acts as your locking hubs. You can tell if you can still see under the truck and your front driveshaft will spin but you wheels dont. If your driveshaft isn't spinning them it's something in the t case
Old 10-19-2011, 01:01 AM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
Here is a flow chart to help diagnose the the issue with you central axle disconnect which is located on the back side of the passenger side axle tube. Hopefully it will be big enough to read.
Old 10-19-2011, 01:09 AM
Color: blue
Rep:23
well I dont think that worked. If it don't come up big enough to read PM me you e mail and Ill send you the full size graphic.
Old 10-19-2011, 08:09 AM
Color: Dark Red
unfortuanetly i only have internet on my phone and wont let me do that kinda stuff i appreciate it tho. think im gunna try and e if the driveshaft spins and go from there. hopefully that thingon the front end is cheap if thats what it is.
Old 10-19-2011, 07:29 PM
dodgeman94 dodgeman94 is offline
Vehicle: 2001 dodge ram
Trim Level: ram 1500 v8 4x4
Color: pearl white
dodgeman94 is on a distinguished road
hey man i have a 2001 dodge ram single cab short bed 4x4 with a 6 inch lift an mine is doin the same thing yours is doin i was wanderin if you found out what was wrong with yours
Old 10-21-2011, 02:19 AM
Color: blue
Rep:23
If the drive shaft spins the first place I would start looking at the vacuum lines for the system. If one is cracked, broke, or unplugged it would cause the front end not to engage. Next I would check the assembly on the front end and make sure vacuum is getting to it. If it is getting vacuum them take the housing off the tube and see if the shift for moves when you shift the transfercase. If it don't the diaphragm is bad and needs replaced. If you are not getting vacuum to the diaphragm then the vacuum switch on the case is most likely bad.
Old 10-21-2011, 02:30 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I just went thru the same problem a coupla weeks ago, and found that there are two tubes that run across the tranny crossmember. theres a silicone rubber coupler hose on the drivers side of the crossmember on each of those tubes, one of mine was off. they are now ziptied onto the tubes, at least they wont just fall off, now... and the engine doesn't knock undr load any more...
Got my Magnaflow system but one problem! RaiderJay6 5.7L (345 cu in) HEMI V8 Specific Topics 12 09-11-2010 07:21 PM
Help with vibration problem ajs3r 2009 Dodge Ram Forum 2 08-19-2010 07:00 PM
Problem with 98 ram with 5.9 Lowrider06 Newbie Checkin! 8 12-23-2009 02:48 AM
Ingnition problem 808state V10 Specific Topics 4 10-31-2009 10:36 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
