Volant Ram Air - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-18-2011, 08:57 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
Default Volant Ram Air
I have been noticing on my Trinity that my intake air temps were very high so I decided to try making a ram air system to use the bottom intake hole in my volant CAI. First I laid it out on a piece of light weight alum and cut the chute
A couple of breaks later I had this
Measure and cut a piece of four inch duct. cut out the slot for the chute
Make a cap for the duct and fasten the chute
to be continued
Old 10-18-2011, 09:05 PM
Rep:404
Test fit it to the lower plastic cover in the bumper and between the frame rails
Paint it up and drill a few dozen holes in the grill piece
Installing it in the truck I found that the tow hooks were going to make it hard to make the piping fit nice so I went and picked up some flexible hose instead. This probably will agitate the air flow so may try something different later. But for now the finished project looks like this
Please feel free to critique or add improvements. Today before I installed it the air temp on evic was 46 degrees and my IAT on my trinity was 97 after install temps dropped to 70 so I feel it was worth the effort for sure
Old 10-18-2011, 10:36 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
I did something almost identical. I'll have to take pics and get them up here. I'm not sure I can say I noticed a difference though...
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 10-19-2011, 01:07 PM
Rep:404
Terry you may not notice but I have been logging with my trinty and have been seeing as much as 100 degree higher temps at the intake from the ambiant temp outside. Now it is about 20-30 degrees higher only. I would say to owners of the volant they should cover that hole if they dont want to do this because all they are doing is sucking in all the heat from under their hood. jmho
Old 10-19-2011, 06:44 PM
TerrysRam's Avatar
Rep:16
You're 100% right. That's what got me thinking about doing it in the first place. Got to looking after I installed it and that opening is right there sucking all that hot under hood air. Figured I may as well make it a true cold ram air if I was going to go to the trouble!
Old 10-21-2011, 10:12 AM
johncran johncran is offline
Vehicle: 2011 Dodge Ram
Trim Level: SLT Big Horn
johncran is on a distinguished road
Any idea when Volant will be releasing their ram air kit for the 2011? When they do I will probably buy one. Til then I was thinking about ram air modding the oem box using a rubber hose similar to one found on a shop vac. 3 or 4 in. dia. would work. Just needed to find a collector for the bottom and mount it in the lower black plastic grill on my slt. Has anybody tried this?
Old 10-22-2011, 09:55 PM
bump to the top
Old 10-22-2011, 10:37 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Fabulous! I really like how you incorporated it into the bumper fill strip. If Volant doesn't come up a good scoop solution, I will take your design and add my own twist to it. Being a Sport, I have a wider slot, so can likely benefit from that. I agree that the flex hose is likely to cause so restriction from air turbulence, but it may take so very creative ducting to do it otherwise.
This is creativity and resourcefulness at it's best, and has earned some well deserved
brad
Interested in one of my mods?
Old 10-23-2011, 06:52 PM
Rep:404
Thanks for the boost Brad! I tried to duct it with pipe but I had to go under the tow hook mount and you would have been able to see it because it would be so low. I wqs thinking of fabbing a duct to go through the tow hook mount but at that point I just wanted to get it hooked up to see what king of IAT drop it would give me.
Recirc door/fresh air intake info and questions starquestbd22 Heating & Cooling 11 07-27-2015 01:04 PM
Comparison highlandchef Total Load Control - Dodge Ram Air Suspension 4 05-29-2012 11:05 PM
Volant 160576 cold air intake 65Arboc 2012 Dodge Ram Forum 5 10-14-2011 09:07 AM
Volant Ram Air? kewlguy53403 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 06-23-2011 12:00 PM
Volant Ram Air mkuchins Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 04-09-2011 07:32 PM
