Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Place your Ad Here!
Old 10-18-2011, 09:01 PM
TruckeeT2 TruckeeT2 is offline
Vehicle: 2014 Dodge Ram
Color: Maximum Steel Metallic
Rep:156
TruckeeT2 has a spectacular aura aboutTruckeeT2 has a spectacular aura about
Send a message via ICQ to TruckeeT2
Question Best TB for my $$$
What is the best TB for my money for my 2010 1500 5.7? Only minor mods (CAI, Headers, & Tuner) Looked at the fastman and BBK. Any other ones to look at?
2014 Dodge Ram 1500 Sport 4x4 5.7L HEMI
2014 Dodge Ram 2500 Laramie Longhorn 4x4 Cummins
2013 Dodge Dart Limited 2.0L
2010 Dodge Ram 1500 Sport 4x4 5.7L HEMI RIPP Supercharged (R.I.P)
2004 Dodge Ram 2500 Laramie 4x4 5.7L HEMI(FOR SALE)
1994 Chevy S-10 Blazer 4.3 Vortex (320,000+ miles)
Old 10-18-2011, 09:03 PM
Rep:3337
I would go with the bbk myself. It's a true 85mm, not a ported tb with the stock butterfly valve.
Old 10-18-2011, 09:08 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2017 Ram 2500
Color: Brilliant crystal black
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
I went with Fastmans TB and both my wallet and myself are truly happy. There are many on here that have went with Fastmans TB and I've yet to here a complaint or a "wish I would of spent more money on a different brand"... But hey, it's your choice and your money....
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 10-18-2011, 09:11 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Have run a fastman on each of my rams and have been impressed every time I buy one of Dan's products.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 10-18-2011, 10:34 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:627
I have one from Modern Muscle that i am happy with. $$ savings you cant go wrong with Fastman.
Old 10-19-2011, 08:58 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Fastman, a lot of work for the money, I've had mine for over a year and it's awesome!!
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 10-19-2011, 09:12 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I also have a Fastman...can't beat the 112 bucks!
Old 10-19-2011, 07:41 PM
Rep:156
Fastman it is. Thanks for all the feedback!!!
Old 10-19-2011, 09:32 PM
Rep:3337
This is from Fastman's site:
STANDARD MODIFIED HEMI TB FEATURES:
-Front Side Taper Boring: The opening of the TB is Radiused and Taper Bored to almost 85mm leading back to the stock bore.
-Half Shaft: Modified Factory Shaft. The top of the shaft is removed promoting even more airflow at wide open throttle.
-(Optional) Backside Bore: I can also offer an optional Backside Taper Bore. The back side is taper bored to match the manifold opening very closely.
The issue I have with these throttle bodies is that they still maintain the OEM sized butterfly valve, and the only part of this thing that is almost 85mm is the opening neck, then it's tapered back to the stock 80mm opening. Even using the venturi effect you increase the velocity of the air flow, and at least he cuts off one side of the axial shaft, but you MAY move more air through this throttlebody, but it will be at a lower velocity compared to the OEM as there's now a longer run length and a faster closure radius. The most important thing to look at is VELOCITY of your flow in a naturally aspirated set up as you need to be able to flow the air into the combustion chamber in the very brief period of the intake valve being open, as well as clear the chamber while both intake and exhaust valves overlap.
If you want some true performance, you want to get yourself a true 85mm throttlebody, either cast or modified to an 85mm butterfly valve. These ported ones are a money grab for people who think that bigger is better, the most part they come with negligable gains.
If you are set on the fastman then pick up his 84mm, which at least has a 84mm bore, not the stock 80mm. The price is comparable to the 85mm BBK; again, more reason to go to the BBK since it's a larger bore for a very similar price.
Old 10-19-2011, 11:17 PM
moparornocar72's Avatar
Rep:630
^good info, I think for some people they want a factory look for the most part under the hood, can't tell the throttle body has been messed with unless u take of the intake or throttle body. That's what I wanted at least.
14.268 @ 95 MPH Full Trim
