Old 10-19-2011, 10:13 AM
johncran johncran is offline
Vehicle: 2011 Dodge Ram
Trim Level: SLT Big Horn
johncran is on a distinguished road
Default How do you SeaFoam your Intake?
I've been reading about the negative effects of the PVC system and how it coats the intake. I've just ordered the Moroso 85479 catch can and am confident this will solve the problem. I've only got 4500 miles on the Ram but would like to know how to Seafoam the intake as talked about here. Can/should the TB removed and cleaned also?
Old 10-20-2011, 08:46 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
You can remove the TB and clean with carb cleaner, being careful not to tear the rubber o rings and seals when removing sensors. To seafoam the intake, remove the brake booster vacumme line from the booster side and dribble seafoam in it very very slowly so not to kill the truck. If you have alot of build up you will probly create a smoke screen...lol but thats normal. Make sure to add some to the fuel to help aid in cleaning the internals of everything. Pretty simple to do, I just let it drip in by covering the seafoam can opening with my thumb and let it dribble.
Mike
Old 10-21-2011, 09:04 AM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
They make a Seafoam spray now for the TB. Are you talking about this or can one just take the intake tube off and spray the seafoam spray directly into the TB?
Old 10-21-2011, 09:17 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Rep:1443
Go to the Seafoam website and watch the how-to videos...that is the best way to get an explination!
I use the spray for the TB and the motor treatment for the gas tank and the oil
http://www.seafoamsales.com/how-to-u...treatment.html
Old 10-21-2011, 09:28 AM
doug713's Avatar
Rep:33
Cool. Great info Timmy. Thanks
Old 10-21-2011, 09:40 AM
Thanks! That's the info I was looking for.
Old 10-21-2011, 09:43 AM
916Timmy's Avatar
Rep:1443
You are both welcome!!!!!
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 09:01 PM
stock air intake question ras119 5.9L V8 Specific Topics 4 11-24-2010 10:13 AM
09-10 K&N Intake Review...Real World Results Inside!! chad3113 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 06-13-2010 12:24 PM
