Old 11-08-2011, 08:51 PM
greenram greenram is offline
Vehicle: 1997 ram slt 4x4
Color: green
greenram is on a distinguished road
I have a 97 Ram 1500 5.9 & it was pinging bad. Was told by a very experienced mechanic to watch for above normal oil consumption and look in intake for oil on bottom of plenum cover. Found oil on cover and the truck started to use 2+ qts of oil between changes. Reviewed a few youtube vids on the plenum cover issue which is very very common. The gasket will let go, oil is pulled in from lifter valley. I suspect the pinging is the result of excessive carbon in combustion chamber from the burning of oil. I bought a new cover/seal kit from Hughes and just put it on. Very stout nice piece, far superior to original. My truck had 98,000 mile so I replaced the original timing set, tension & idler pulley, water pump, hoses & belt, plug wires, therm. at the same time. I was also told to look for excessive corrosion on the aluminum timing cover where it mates to the water pump, mine wast too bad. I would recommend using original MOPAR parts if possible or at least made in the USA. You don't want to have to tear into it again because cheap part were used. Not exactly a afternoon job but doable for the average wrench. Hope things work out.
Dave FNG
Old 11-09-2011, 01:03 AM
Rep:2657
The Hughes Plenum Kit is suppose to be the cats meow
Old 11-13-2011, 09:19 AM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
http://www.hughesengines.com/Index/p...3&partid=26190
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
Old 11-13-2011, 10:16 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
if you want to look for a possable vac leak I think there is a test port on the purdge silenoid evap can its behind right headlight, it has a green cap on it.
Need Help or Advice PINGING NOISE C J R 2009 Dodge Ram Forum 11 08-06-2011 01:32 AM
pinging sound javier 2010 Dodge Ram Forum 3 04-09-2011 02:38 PM
engine pinging new dodge man Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-16-2010 11:50 PM
Pinging with Superchips and 91 octane ilovetards Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 02-10-2010 03:32 AM
Pinging Lowrider06 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 10 12-22-2009 08:13 PM
