Rear wheels won't come loose! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-19-2011, 11:16 PM
Liphter Liphter is offline
Vehicle: 95 Dodge Ram 1500
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Liphter is on a distinguished road
Default Rear wheels won't come loose!
Hey all,
I'm replacing the wheel valves on the rear and front callipers on my "new" (1995 1500 4x4)...at least that's what I was trying to do. The truck sat for quite some time and I just got it up-n-runnin and back to my shop. The brakes needed to be bled but I tried everything that I knew to move the bleeders and nothin, so I decided I'd limp it home and deal with it there. It took me nearly 3 hours to just get the lugs to turn on all four tires...lubes, torque, blow torch...they were friggin fused on tighter than a welded joint!!! I even had to cut one of the bolts off...that said, I finally got all of the lugs off and pounded on the front tires and they came off with a little 8lb mallets help but the rear wheels wont budge! My buddy tells me that his ma had the same problem after less than 6,000 miles on her car and its common for steel wheeled vehicles...but I've never had a problem like this before. It's sat for a long time and I can feel the rust inbetween the rim and drum so I'm soakin it for the night. Anyone know of a quick trick to splittin these bastards off this damn thing!!??
Thanks ahead of time,
D
Old 10-19-2011, 11:18 PM
I'd try some penetrating fluid, then a sledgehammer from the backside.
Old 10-20-2011, 09:01 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Ive never had that problem with steel wheels only aluminum. I go with the sledge on front then back, side to side.
Old 10-20-2011, 12:26 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
as mentioned, pull out the sledge
Old 10-20-2011, 02:07 PM
HaydenWar's Avatar
HaydenWar HaydenWar is offline
Vehicle: 2010
Rep:45
HaydenWar is on a distinguished road
I had this problem with the front wheels on my 96 Sebring, no amount of sledge would get them off, I finally ended up loosening the lug nuts and driving around the block to break it loose one set of new studs later it was fixed.
Old 10-20-2011, 02:35 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Wisconsin- salt on roads- 'nuff said.
Sounds like you 're taking the right steps.....
Old 10-20-2011, 02:54 PM
shujat shujat is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Sport 4X4
Color: Mineral Gray
Rep:19
shujat is on a distinguished road
+1 on the sledge, nice and easy......
Old 10-20-2011, 03:14 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Lube and a BFH.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 10-20-2011, 03:15 PM
Rep:24
^^^ sounds kinky
Old 10-20-2011, 03:55 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Same problem here with my 97... The 4x4's wheels are tight on the hub due to the stress of off roading and hauling and all that so a little rust scale built up on those hubs where they stick past the rim ...soak them good with wd or any penetrating oil and use a wire brush to remove as much rust as you can, once the wheel starts to move it will come off easily, Took me almost 20 minutes of beating on it with a 6 pound sledge but got it... just rotate the wheel as you beat away... or if youre replacing the wheels just knock em with a standard sledge....lol
Just take your time so you dont warp a rim if you are keeping them.
I Am Groot !
Need help finding Grey wheels boldy Dodge Ram Wheels And Tires 4 10-12-2011 11:05 AM
Got my build sheet....now I have questions... jandrso 2011 Dodge Ram Forum 14 09-18-2011 04:30 PM
Rear Caliper Torn Loose RamPiper Suspension 1 05-11-2011 01:09 PM
Rear End Questions.... jared1088 Suspension 2 04-18-2011 08:50 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
