Old 10-21-2011, 01:54 AM
Liphter Liphter is offline
Vehicle: 95 Dodge Ram 1500
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Liphter is on a distinguished road
Thanks guys...I've gotta admit, I was close to gettin the die cast cutter and a plasma torch and chalkin this one up to anger management!!! But a buddy of mine stopped over and we went on a hunt for penetrating....fluids!!!....and a massive sledge...NM...after the drinks at the local that is! That said, we did find a our best combination, 2 penetrating oils, wd40 and a 12lb sledge..oh and a few more cocktails!!! Finally, the wheels are off the damn truck, thank god I didn't drive and get a flat...would've been screwed then...Nonetheless, We finally got all four off...only to encounter our next issue, rear drums...(took an hour of smashing on each plus our formula..lol..) The fronts...well,they were a bit of a pain in the ass as well but are off of the truck so that's good!! What should've taken a maximum of 2 hrs...has somehow turned into 12...that said, the brakes will be the least of the issues after tomorrow morning..now on to the traction bars and bearings and gaskets and sleeves and ball joints...that's about all Ive got for now..I'm sure there ll be more to come soon!!!
Thanks ahead of time,
D
Old 10-21-2011, 02:15 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Get out your torch and heat the center hole of the wheel up, the axle end and the center hole of the wheel tolerances are so tight these days, it takes virtually no corrosion to fuse this joint. once heated, a pry bar between the drum and wheel from the back, Not a lot of tension is required, and one good slam on the tire (not the wheel) opposite where the pry bar is, will 'get er done' for ya. I personally open up the hole on the wheel on the first time I have em off, you only need remove a coupla thousandths. also, careful on alloys, they tend to leave some wheel corrosion white stuff around the axle end, which will generally leave you with a loose wheel after 50 miles or so if you don't scrape the stuff off the axle end while the wheel is off. It doesn't hurt to scrape the rust off the axle end before you try to remove your wheel, if theres any axle end exposed (doubtful, tho)
Old 10-21-2011, 12:54 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Now that they are off ant sez on all contact points of the hub. Thats how I curred the issue with my aluminum rims.
Old 10-26-2011, 02:17 PM
southbronxems southbronxems is offline
Vehicle: 1994 Dodge Ram 1500
Color: Dark Blue
southbronxems is on a distinguished road
Just did my rear wheel cylinders and had the same issue on one side, including the lug issue, (thank god for the torch). Give it a few back kicks, like a donkey. Sledge didnt do it for me...
Old 10-26-2011, 02:21 PM
Color: Dark Blue
Forgot to mention, if you mix tranny fluid and acetone (nail polish remover) 50/50, it works better than any over the counter penetrating oil.
Old 10-26-2011, 04:07 PM
dylancarlson07's Avatar
dylancarlson07 dylancarlson07 is offline
Vehicle: 2007 dodge ram
dylancarlson07 is on a distinguished road
kick the tire on oposite sides as hard as possible "HIT IT WIT UR PURSE"
Need help finding Grey wheels boldy Dodge Ram Wheels And Tires 4 10-12-2011 12:05 PM
Got my build sheet....now I have questions... jandrso 2011 Dodge Ram Forum 14 09-18-2011 05:30 PM
Rear Caliper Torn Loose RamPiper Suspension 1 05-11-2011 02:09 PM
Rear End Questions.... jared1088 Suspension 2 04-18-2011 09:50 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
