Old 10-20-2011, 05:55 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Remote Door Fob
My Ram didn't come standard with a remote door operating fob, but I'd love to have one. If I buy one, either OEM or aftermarket, is there something else I'd need installed inside the door(s) for that to work? My locks are electrically operated by pushbutton, but I suspect that there must be some other component that receives the signal and then that tells the locks how to operate?
Old 10-20-2011, 07:13 AM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Nope wont need anything the truck already has everything I got mine done at the dealer for 339 installed
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 10-21-2011, 02:50 AM
Dancianne's Avatar
Rep:136
That sounds great! Love the convenience and will get one next time I am by there !
Thank you !
Old 10-21-2011, 06:51 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
If all it needs is a new key fob why is it so expensive. The dealer just bought me a new key fob and an new key. It was 219 programmed.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 10-22-2011, 04:22 AM
Dancianne's Avatar
Rep:136
Default keyless fob
I see one on the aftermarket side from iKeyless.com that resembles the 2-button OEM style exactly, being offered at 69.95 but it would have to be programmed. It includes a blank key which can be cut to fit the door but does not start the engine. I have not checked to see what the dealer charges for programming, but I have read up on a procedure where user programming is possible if you have two original ignition keys,...similiar to programming a garage door opener. That may or may not work with the Ram. Probably only sure way to go is back to the dealer for everything.
Old 10-23-2011, 08:56 AM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
My dealer refused to install a Mopar part, so I went to BestBuy and had them install a Viper remote start. Compared to the factory remote starter on my work trucks the viper blow them away.
2000 foot range
remote confirms lock/unlock/start via led lights and beeps
if started it alerts you when the vehicle has been started for more than 10 minutes, and you can reset the timer to allow it to keep running.
can hit the remote start button and take the key out and leave the motor running while making a quick stop.
even have the ability to check the temperature in the vehicle through the remote.
I'm a big fan of viper, and have their security tint installed as well (prevents glass from shattering if someone tries to break in).
NewB Problem with Remote Start TexasParamedic Electrical 6 10-31-2011 02:14 PM
RKE and Remote start billzthe1 Electrical 13 07-23-2011 01:38 PM
2008 key with no remote? GPGT1 Dodge Ram General Discussion 2 01-18-2011 10:38 AM
Remote Garage Opener brolland 2010 Dodge Ram Forum 16 04-01-2010 07:16 PM
Remote Start and Alarms, Fog Lamp Mod ohioman911 Newbie Checkin! 9 12-14-2009 04:44 PM
