Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 10-20-2011, 01:32 PM
genesis5521's Avatar
genesis5521 genesis5521 is offline
Vehicle: 2011 Dodge Ram 1500 Tradesman
Trim Level: Tradesman
Rep:32
genesis5521 is on a distinguished road
Default Want your opinions on better high beam headlights.
I have a 2011 Ram 1500 Tradesman. Maybe it's just me and I'm getting old (65), but it's getting harder for me to see things at night while driving. I'm thinking that the stock high beam headlights could be better/brighter, wider, etc. Have any of you tried other bulbs? I don't wanna go the HID route just yet. I first wanna try some different bulbs. Tell me what you've tried and what worked best. Also like to know what to stay away from. Please provide manufacture and part number.
Thanks guys (and girls).
Luv this forum
Don <><
Old 10-20-2011, 02:11 PM
goingcrazy goingcrazy is offline
Trim Level: sport
goingcrazy is on a distinguished road
I'm with you. I want better lights but the HID/TPMS issue limits us. I used Sylvania SilverStars in previous cars and got a little improvement. Don't have any part numbers for the Ram silverstars yet. Prices range from $15-$30 depending on the style. I'm holding out in hopes that someone comes up with a solution to the HID/TPMS problem.
Old 10-20-2011, 02:20 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
If your not looking to go the HID route look into any sort of PIAA bulb. IMO silverstars arent much more than a WHITER light than stock type bulbs.
You could also go with LED, though I have never seen how they do in hi beam applications
2011 Big Horn 4x4 -SnowWhite-
Old 10-20-2011, 02:36 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Try Phillips CrystalVision. They are 4300-5k temperature (just about bright daylight with very little blue tint) and should drop in to your stock housings. That will make things brighter but the light pattern will be the same unless you change housings.
Old 10-21-2011, 11:21 AM
squig69 squig69 is offline
Vehicle: 15 quad cab
Trim Level: sxt
Color: granite metallic crystal
Rep:13
squig69 is on a distinguished road
im looking at changing the bulbs also as i dont want to go the route of changing out the housing yet, though i havent seen the Philps brand in any of the shops ive been in so my only option (as it seems) is the Silverstars
just picked up a pair of the PIAA bulbs. now all i gotta figure out is how to get the old ones out and the new ones in
things out of square make me cry
Old 03-13-2012, 06:35 PM
Denix's Avatar
Denix Denix is offline
Vehicle: 2015 Ram 1500 4x4 Crew Cab
Color: Maximum Steel Metallic
Denix is on a distinguished road
I'd like to change mine too. Is it easy to replace the bulbs? Thanks, Denis.
Old 03-13-2012, 07:23 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
i have putco mirror white, crap.....no better...the hibeams on my truck are useless..mite be ok if the fogs stayed on. i did find improvement with 9005 in the fogs and h9's in the lows.
2015 blacked out sport 4x4 qc
Old 03-13-2012, 07:47 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I have silver star ultras for hi and low and they are a lot better than the stock bulbs! I rarely use my high beams anymore
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 03-13-2012, 08:50 PM
hortence222222's Avatar
hortence222222 hortence222222 is offline
Vehicle: 2014 Ram Sport RCSB 4X4
hortence222222 is on a distinguished road
Default Piaa
Well, after reading and reading and reading more, I finally opted for some PIAA Extreme White Plus bulbs. I have the 2 headlight (as opposed to 4) system so my truck uses the H13 bulb. They are noticibly better than the stock bulbs. I was considering some of the really bright bulbs, but tales of melted wiring harness's etc scared me off.
As for changing them, it is a PITA... If you can get your head in the wheel well to actually see how the sliding lock tab works, its easy. Two bolts accessed from the top (under the rad/grill plastic cover) and then the sliding tab. Good luck..
Old 05-20-2013, 01:50 AM
shortbox81 shortbox81 is offline
Vehicle: 2011 dodge ram
Trim Level: R/T
Color: Grey
shortbox81 is on a distinguished road
try leds. just put them in my fogs nice and bright will replace head light bulbs once I change the head lights.
Lamp Out Indicator & High Beam Hesitation Black05 Electrical 2 07-17-2011 04:38 PM
High beam not working grs Electrical 6 07-13-2011 12:51 AM
High Beam issues sonocativo Electrical 30 04-09-2011 02:37 PM
Tap KC Lite switch into high beam headlights? KirkCJohnston 2009 Dodge Ram Forum 11 04-28-2010 01:15 AM
No Low Beams - High Beam position gives Low Beams daveruybal Electrical 3 02-21-2010 07:31 PM
