Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 10-20-2011, 04:19 PM
Superdave450 Superdave450 is offline
Vehicle: 2012 1500 Sport
Superdave450 is on a distinguished road
Default Gague cluster in both MPH and KPH?
Im looking at importing a US 4th gen Ram into Canada. One of the stipulations is the Odometer needs to read in KPH. Can this be changed internaly in the cluster setting or do I have to change it out?
Old 10-20-2011, 04:25 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
You can't buy a 2011 from a Dealership within your province? It should be a direct replacement since its oem matching if you the trim is the same. Just dont disrupt the needle positions.
Old 10-23-2011, 03:35 AM
Anyone done this?
Old 11-26-2011, 11:47 PM
Tonka's Avatar
Tonka Tonka is offline
Vehicle: 2011 Ram 1500 Quad-Cab 4x4
Tonka is on a distinguished road
There is a metric setting that is accessible through the steering wheel controls on my 2011 sport. I haven't used it in metric mode yet, but I would assume that it changes the speedometer settings as well. I'll try to verify this through gps when I get a chance.
I do know for sure that the odometer, temperature and tire pressure readings will show Kilometers, degrees Celsius, and kPa, respectively.
Old 11-26-2011, 11:58 PM
That ^^^^ is correct. If you have EVIC on the truck you are bringing in, the odometer will have a metric setting.
