Old 10-20-2011, 05:14 PM
shujat shujat is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Sport 4X4
Color: Mineral Gray
Rep:19
shujat is on a distinguished road
Default 4X4 Question
So my truck is my first 4WD drive truck, I have owned AWD in the past, but need a quick 101 on using the five options at my disposal.
I have:
2WD (obivous)
4WD Auto (Does this mean 2WD until slippage, than 4WD???)
4WD Lock (Does this mean AWD? or 4WD HI, in which two wheels, one on each axle are on, until slippage?)
4WD LO (I get this one)
Your help is appreciated.
Thanks!
Old 10-20-2011, 05:18 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Yoiu pretty much have the right idea.
4hi is both axles in regular gear. How many tires that actually spin depends on the axle, wether its locked or limited slip or just an open diff.
4 lo is a reduced gear 4 wheel drive
Old 10-20-2011, 05:26 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
I have:
2WD (obivous) Good on ya!
4WD Auto (Does this mean 2WD until slippage, than 4WD???) You're in 4WD, with all wheels driving you. Power will split between the front and rear axles as necessary based on slip because of a center differential. You're OK to use this on paved roads in the dry.
4WD Lock (Does this mean AWD? or 4WD HI, in which two wheels, one on each axle are on, until slippage?) You're in 4WD, with all wheels driving you. The power is split between the front and rear axles equally- the center diff is locked. DO NOT use 4hi on dry roads- use in snowy/muddy/sandy areas. Also, there is no gear multiplication- the truck will drive as normal gear wise.
4WD LO (I get this one) Same as above with gear multiplication
Thanks!
Hope the above helps!
Old 10-20-2011, 05:29 PM
Rep:24
#5 is neutral- allows you to disengage power from reaching both front and rear diffs.
Old 10-21-2011, 12:24 PM
Color: Mineral Gray
Rep:19
Thanks everyone, very helpful, so #5 NEUTRAL would be used what kind of situations?
Old 10-21-2011, 12:43 PM
Rep:24
You might want to break out the owner's manual- it's a fascinating read
http://www.autodealertools.com/quick...Ram%202500.pdf
Section 5, page 334 to 340
I was wrong on 1 point- the auto 4WD is more of a slip sensing system that diverts power to the front wheels as needed, but generally operates in RWD until needed.
2010 headunit change question ddtb2010ram Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 03-23-2011 04:06 PM
factory exhaust question tough question 460hpmach1 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 13 05-26-2010 10:47 PM
Question Regarding Replacement LED Bulbs marko7717 Custom Dodge Ram Interior and Exterior Lighting 5 03-22-2010 10:43 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
Grease fitting question. pghram1500 Dodge Ram General Discussion 2 07-22-2009 09:12 PM
