Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 10-20-2011, 06:33 PM
moparornocar72's Avatar
Rep:630
Default How To Interior Bulb Change (pics)
I changed my lights out to l.e.d.s from superbrightleds.com today thanks to SS4Luck's help with the correct part numbers! Anyways just thought I would pay it forward and give those of you that don't know how to get your lenses and bulbs out a write up!
Tools Needed:
Small Flat Head Screwdriver and a 2 small zip ties if wanted (read step 5)
Reading or Map Lights:
  1. Disconnect and isolate the battery negative cable.(I DIDN'T)
  2. Using a small thin-bladed screwdriver, gently pry near the front of the lamp lens between each side and the overhead console housing (1) to unsnap the pivot tabs (3) on the lens from the pivots in the lamp housing.
  3. With the lens disengaged from both pivots, pull the lens forward far enough to disengage the switch tab (2) on the rear edge of the lens from the slot in the rear of the overhead console lamp housing.
  4. Remove the lens from the housing.
  5. Pull the light bulb straight down. (Mine were hard to grab so I improvised with a zip tie at the base, came right out)
Rear Dome Light:
  2. Insert the tip of a small flat bladed screwdriver into the notch (5) between the lens (2) and the housing (1) on one side of the dome lamp unit.
  3. Gently pry the end of the lens outward until it unsnaps from the housing.
  4. Swing the lens outward until it is perpendicular to the housing.
  5. Pull the lens hinge/retainer end (3) of the housing outward slightly from the headliner, then slide the exposed end of the housing away from the mounting hole far enough to disengage the fixed retainer (4) on the notched end from the headliner.
  6. Pull the lamp away from the headliner mounting hole far enough to access and disconnect the wire harness connector from the back of the lamp.
  7. Remove the lamp from the vehicle. (Pulls right out)
This all takes maybe 5 minutes, just be sure not to break the lens.
14.268 @ 95 MPH Full Trim
Old 10-21-2011, 09:47 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Nice write up man.
It was a PITA for me to get the bulbs out of my map lights, i have to do it with a set of nedle nose pliers and I ended up shattering a bulb. Picking up all the little pieces of glass over the shifter consol is not the greatest way to spend 30 minutes lol
2011 Big Horn 4x4 -SnowWhite-
Old 10-21-2011, 12:01 PM
Rep:630
Thanks. I was about to grab pliers then remembered how often i shatter bulbs. Zip ties it is.
Old 10-23-2011, 10:59 PM
11BLACKHEMI 11BLACKHEMI is offline
Vehicle: 2011 Ram 1500
Trim Level: Crew Cab Big Horn
Color: BLACK
Rep:48
11BLACKHEMI is on a distinguished road
And what would those part #s be?
Old 10-23-2011, 11:07 PM
Rep:630
x2 921-NW12 map lights
x1 4210-CWHP6 rear dome light
Old 10-24-2011, 12:45 AM
millon9's Avatar
millon9 millon9 is offline
Vehicle: 2006 Dodge Ram MEGA cab
Color: Dark Grey Metallic
Rep:137
millon9 will become famous soon enoughmillon9 will become famous soon enough
Now we just need a write up for 3rd gens!
But awesome write up! Very nicely written, and informative. Rep'd
MY BUILD THREAD
http://ramforumz.com/showthread.php?t=95334
www.woundedwarriorproject.org
Donate and help the people who gave limbs to help you!
Jason
Old 10-24-2011, 02:28 AM
Rep:630
I'll do it if u send me ur led interior light pics!
Old 10-24-2011, 04:30 AM
millon9's Avatar
Rep:137
I will be ordering my interior lights most likely next weekend or so, after I get it, I'll have pics, and we can get a good write up done.
MY BUILD THREAD
Jason
Old 10-24-2011, 12:50 PM
Rep:630
We'll do it sir!
Old 03-11-2012, 12:39 AM
vixtarr vixtarr is offline
Vehicle: 2004 DODGE RAM LARAMIE
Trim Level: LARAMIE
Color: BLACK
vixtarr is on a distinguished road
whats the cost for the kit?
Determining Speedometer Error Due To Tire Size Change MADDOG Dodge Ram Wheels And Tires 16 01-04-2015 07:33 PM
How to change disk brakes double0ram Dodge Ram Knowledge Base 16 05-25-2012 08:28 PM
how to change the fuel filter on a 92 maxivan wpatters1229 Dodge Ram General Discussion 1 09-09-2011 02:56 AM
2011 Ram Oil Life Per Oil Change uncletony76 Oil Change 31 09-05-2011 07:34 PM
change oil indicator greendaze Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 01-08-2011 04:46 PM
