Old 10-22-2011, 10:10 AM
Bobandmuriel Bobandmuriel is offline
Vehicle: 2011 Dodge Ram Hemi
Bobandmuriel is on a distinguished road
Default Towing with my 2011 Hemi
Hello, I am a Newbie to his site. We just purchased a new 2011 Ram with the Hemi engine and plan to pull a new (future) trailer with it. Not sure yet if it will be a travel trailer or a 5th wheel. I'd sure like to hear from other owners how their experience has been with the Hemi as a tow vehicle.
Thanks in advnce.
Old 10-22-2011, 12:09 PM
Zalman's Avatar
Zalman Zalman is offline
Vehicle: 2011 Ram Sport Thunder Road
Rep:22
Zalman is on a distinguished road
You should be just fine. Ive got a 26 foot bumper pull that I pull regularly (in the summer) with my hemi. I've got 3.93 anti slip rears and the tow package with factory brake controller in mine and I can go up a 10% grade at 130 km/hr! That's over 80 miles/hr for you folks to the south. 5th wheels tow even easier than a bumper pull. I'd say you should be good to anything up to around 28-29 feet in length unless you're looking at getting a toy hauler camper, then you may need a diesel.
Old 10-22-2011, 12:14 PM
The towing experience has been fine. You just want to make sure you have the right hitch for the load and don't exceed your GVWR when hooked up and ready to go.
Old 10-22-2011, 12:18 PM
Default Towing
Zalman:
Thanks for your reply.
I too have the 3.92, the towing package and built in break control.
Can you share with me.......what is your trailer, do you know what its weight is etc??
Bob (AkA Bobandmuriel)
Old 10-22-2011, 07:53 PM
x96mnn x96mnn is offline
Vehicle: 2014 3500 DRW Crew Cab RAM
Trim Level: Farmers Package
Rep:28
x96mnn is on a distinguished road
I tow 29ft rvision, weighs about 4700 to 5000pds loaded. I have the standard rear but tow package and factory brake control with a Reese dual cam sway weight distro system. The hitch system most likely is not needed but was with my last rig.
I can go as fast as I want to go but when I am pushing 70 miles I pay for it at the pump. average probably 7 to 8 miles per gallon. Now if I keep 60 miles and let it lose some speed on the hills and pick back up on the down hills or flats I can pull and easy 12 to 13 miles per gallon out of it.
Old 10-22-2011, 09:12 PM
Rep:2657
This is just a guess
Quad cab, Hemi engine, 3.92 axle ratio, Class 4 hitch receiver
weight of 3 adults, bed loaded
you should be able to pull a loaded trailer weighing 7,000 pounds
i would load the Ram with what you plan on having in it while pulling a trailer, go to a PUBLIC SCALES, Mayflower & other moving companies usually have a set of scales, walk up to the scale house, there will be a Weigh Master inside. Tell them what you want to do & let him know that do NOT need a Certificate, he will likely tell you to pull on the scale & he will orally give you your weight, most times they won't charge you because he didn't need to do any paper work.
Using that weight, lets you know what weight trailer that you can pull
anything over 5,000 pounds should also have a weight distribution system
Old 10-22-2011, 11:15 PM
bobbyhit bobbyhit is offline
Vehicle: 2011 Ram 2500
Trim Level: Work Truck
Color: Grey
bobbyhit is on a distinguished road
Default Towed mine today
Hello,
I towed my 2006 Crossroads Cruiser home today. my 2011 Ram 2500, 5.7 L towed it much better than the 02 Chevy 2500 6.0L did. The camper is a fifth wheel. Stopped at the weight scales on the way home. Camper weighed 9,880 lbs. Pin weight was 2,280 lbs. With the 2500 I was within all gross weight limits. Towed great. Averaged 8.9 MPG. Average 17 to 20 MPG when not towing. Love the truck.
Old 10-23-2011, 06:05 AM
16again's Avatar
16again 16again is offline
Rep:58
16again will become famous soon enough
16' steel trailer with my 3400lb car on it. Tows fine, actually have to remember it's back there. No shortage of power and quite stable at highway speeds.
2011 dodge ram 1500 hemi regular cab 4x4 semichigan Dodge Ram For Sale - Used Dodge Trucks 4 11-09-2012 03:50 AM
Just Bought 2011 Hemi ram sprt quad cab Hemiram2011 Newbie Checkin! 13 07-27-2011 07:04 AM
Towing with our new 2011 2500 Hemi t05ks Towing 1 07-25-2011 10:24 AM
2011 Dodge Ram 1500 SLT 4X4 Hemi ! wall23b Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 07-18-2011 05:59 PM
2011 1500 Hemi mods MOHog Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 02-21-2011 01:47 PM
