Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-20-2011, 08:31 PM
steven.pomales steven.pomales is offline
Vehicle: dodge ram 1500 4x4 quad cab
Trim Level: Lone Star
steven.pomales is on a distinguished road
Default replacing shock with 2" longer Daystars
has anyone replaced only the shock instead of replacing the entire assembly? If so is it something I can pull off in my driveway? I'm trying to avoid paying a ton for 2 quick struts. Also, if this is something I can do will a shock that is 2" longer than a stock shock fit the same inside the spring and on the mount without any mods?
Thanks.
Old 10-20-2011, 08:32 PM
Oh, and if anyone cares, I'm brand new to the forum.
Old 10-20-2011, 08:38 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well welcome to the forum! What year is your truck? They used a different suspension from 02-05 then 06-08
Old 10-20-2011, 08:59 PM
She's a 2007 4x4
Old 10-20-2011, 09:23 PM
Color: Mineral Gray
Rep:177
Then you can get ride height adjustable shocks to raise your trucks front end. A regular shock that is two inch longer isn't going to do anything.
When you mention daystar, you can also install spacers to level the front of the truck and install +2" shocks to compensate the difference in your ride.
It's not a hard task to install new struts, it is a little involved but manageable with basic tools
Old 10-21-2011, 12:44 PM
sounds easy enough. thanks for the input. Do you know if removing the strut from the spring requires any special tools? ie. spring compressor, etc...
Old 10-21-2011, 12:49 PM
Anyone have any advice on some good ride adjustable shocks, affordable and durable. I dont have much experience with these and would like to hear what everyone else thinks rather than read product descriptions.
Bilstein B6 Heavy Duty Shock Install w/Pics wolfman10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 15 01-09-2014 08:49 AM
