Old 10-21-2011, 01:47 AM
11BLACKHEMI 11BLACKHEMI is offline
Vehicle: 2011 Ram 1500
Trim Level: Crew Cab Big Horn
Color: BLACK
Rep:48
11BLACKHEMI is on a distinguished road
Default Fuel Mileage!?!
Ok so I just put a 2.5" Hell Bent Steel Lvl kit and 305/55/20 Nitto Trail Grapplers on my 2011 1500 CC and have already noticed it drop a considerable amount in fuel mileage(about 3-5mpg)
What can I do to help with fuel mileage? K&N drop in? Anything else?
PLEASE let me know as I drive 40+ miles round trip everyday if not more!!!
Thanks
Old 10-21-2011, 01:54 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
It's going to tough to get a marked improvement in mileage with the lift and those tires.
A K&N drop in will help....but mostly at high RPM. Exhaust will also help a bit....but in reality, a lift with big tires is harder on overall mileage then most things.
You could also try using 89 octane fuel and resetting the computer so it hopefully adjusts to the higher grade fuel and gives you some performance benefits.
brad
Interested in one of my mods?
Old 10-21-2011, 02:31 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
having the huge rake with the nose to the ground makes the biggest difference with your mpg. That is why the nose is so low and they add that big air dam at the bottom of the bumper. If you can keep the air from traveling under the truck, you reduce the drag significantly. When you level it, you change the air drag on the truck. Add an extra 10-20 lbs on the end of the axles and you have more resistance to spin. Kind of sucks but it is more functional and looks much better.
I know when I did a CAI and the exhaust on my Silverado I gained about 1mpg. Not bad for a $250 investment.
If i can kill it with an arrow, I'll eat it.
Old 10-21-2011, 08:16 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Gear it... about the only thing you can do to try and recover any sort of MPG with large heavy tires like that. Help the truck spin the tires a little easier
2011 Big Horn 4x4 -SnowWhite-
Old 10-21-2011, 09:20 AM
JF2004's Avatar
JF2004 JF2004 is offline
Vehicle: 2013 Ram 1500 Longhorn 4x4
Trim Level: Laramie Longhorn
Color: Maximum Steel Metallic
Rep:22
JF2004 is on a distinguished road
I am in the same situation right now. I switched to 89 already no significant change. K&N drop in doesn't do much either. But I would like to know how to reset my computer to try that to see if it helps...
YEAH, IT'S GOT A HEMI
Old 10-22-2011, 02:21 PM
NashvilleHemi's Avatar
NashvilleHemi NashvilleHemi is offline
Vehicle: 2004 Dodge Ram
Color: Dark Molten Red
Rep:24
NashvilleHemi is on a distinguished road
Get a programmer like Diablo or SuperChips and set it to economy!! Thats what i'm about to do bc the gas prices went up again as soon as the news reported it goin down!!
Dynomax cat-back, K&N CAI 77series, AFE TB spacer, Trick Flow 20% underdrive balencer, MSD 8.5 wires, e3 plugs, 3865 Super Chips, Fastmans ported TB, 180 T-Stat
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 07:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
