Old 10-21-2011, 02:52 AM
logtice's Avatar
logtice logtice is offline
Vehicle: 2001 Dodge Ram 1500 5.2 V8
Trim Level: base
Rep:17
logtice is on a distinguished road
Question First 6 days and 1000 miles later...
Truck is still running amazing! lol i took this pic going down the highway, i was looking to see if i could get over and all i see is my bedliner flying a foot above my tail gate!!! i about crapped my pants haha i had already been on the road for an hour before i notice it was doin that! pulled over at the next exit and let down the tailgate, end of story =]
Alright ive got a question, is it normal? When in cruise and in overdrive, i start up a hill, and as my RPM begin to climb, my A/C stops blowing. but once i top the hill and the RPM's level back out to 2000, it kicks right back on....
Old 10-21-2011, 07:05 AM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2014 Ram
Color: True Blue
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
Send a message via AIM to RockyRam
Lucky you caught it or may have ended bad
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 10-21-2011, 09:47 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Sounds like compesor clutch is kicking out. Might be a bad relay or pressure sensor, but more then likely its just low on freeon. But if you tow and rpm jump up suddenly like a down shift will kick it off but you should not notice in the cab.
Old 10-21-2011, 09:49 AM
ramfam's Avatar
Trim Level: Base
Rep:21
By the way nice pic. Im waiting for my bed liner to do that!
Old 10-21-2011, 02:38 PM
logtice's Avatar
Trim Level: base
Rep:17
haha thats what im sayin! i started freaking out after i saw it!
with the A/C could it also have something to do with P1740???? like i said ive put 1000+ miles on it this week and the ac is all ive noticed, overdrive is still kicking in when its supposed to and stays engaged thru all hills.... sooo idk?
Old 10-21-2011, 05:03 PM
ramfam's Avatar
Trim Level: Base
Rep:21
call your local auto zone tell them what code you have. it might have some thing to do with it. the computer has alot to do in these trucks. almost crazy amount!
Old 10-22-2011, 12:29 AM
Trouble's Avatar
Trouble Trouble is offline
Vehicle: 1997 ram 1500
Color: red over silver
Trouble is on a distinguished road
You have a vacuum leak in the heat/air system, it defaults to defrost under low or no vacuum.
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
the bedliner didnt fly out when you opened the tailgate? lol
Old 10-22-2011, 02:05 AM
logtice's Avatar
Trim Level: base
Rep:17
Thats exactly what it is! i hear little plastic pieces in the duct work moving around when it happens! then kicks back to normal, so if i keep running it as is, will the problem get worst or will the A/C cut out all together?
Mr. Lopar, once i put the tail gate down, i tied a rope across the back hooks on the bottom to make sure it didnt fly up any higher. but once back on the road, the wind coming over the cab pushed the bedliner down and it no longer flys like that!
Old 10-22-2011, 12:37 PM
ramfam's Avatar
Trim Level: Base
Rep:21
I run 90% of the time my tailgate down anyway. So I guess I won't have to worry about mine going for a flight.
2001 dodge ram, 5.2 liter, air conditioning, bedliner, overdrive
gen 4 cam swap 1000 mile initial review autobred Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 44 05-18-2011 12:35 PM
