Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 11-28-2011, 09:58 PM
Tpellus Tpellus is offline
Vehicle: 2003 Dodge Ram 1500
Color: Dark Pearl Red
Tpellus is on a distinguished road
I have 3.92 in my truck right now. Would going up to 4.10 make that much of a difference? I have an aftermarket exhaust on already, and am planning on putting a CAI on and then getting a tuner. Most people have recommended superchips.
Old 11-29-2011, 09:04 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
3.92 to 4.10 would be nearly no change. You'd likely want to go to 4.56. I have a superchips and love it, it makes a huge difference, but I have read some 4.7L guys in your year range that didn't like it and couldn't tell a difference.
Sean
Old 11-29-2011, 10:23 AM
Alright, well then I will most likely skip gears, unless I decide to go to 35's once I am finished with my extremely long list of mods haha. Doesn't ever seem to end.
Old 11-29-2011, 05:50 PM
440Magnum 440Magnum is offline
Vehicle: 2008 Ram 1500
Trim Level: Lone Star
Rep:20
440Magnum is on a distinguished road
Your truck has two overdrives (4th and 5th gear). Most vehicles up until recent years basically all had the same overdrive gearing, which was 0.75. Your ram has that, but then another gear (0.67). This gives a lower cruising rpm for better mpg.
Just to clarify what snrusnak said, Your 545RFE transmission has SIX forward gears. Chrysler calls them 1,2,2',3,4,5 where 2' is pronounced "2 prime." In normal driving, the transmission shift pattern is 1-2-3-4-5, where both 4 and 5 are overdrive gears, and it skips 2'. The torque convertor locking and unlocking makes it really hard to tell a gearshift from a TC lock when you're driving and it seems like you can count about 7 shifts... but there are only 5 true gear changes Whenever you accelerate hard and the transmission has to downshift lower than 3, it picks 2' instead of 2 to give you better passing performance without winding the snot out of the engine. That's all 2' is used for until you factor in that little button on the end of the gearshift (or on the dash on some models).
Some years of Ram have only an "O/D OFF" option using the button on the end of the gearshift, but others also have "Tow/Haul" mode. When you pick T/H mode, the transmission shifts 1-2-2'-3-4, and all the shift points are moved up in RPM. It never goes into the 2nd OD (5th gear, the 6th ratio in the tranny). If you pick "O/D off," then it shifts 1-2-2'-3 where 3 is the direct 1:1 ratio gear (or it may just be 1-2-3, I'm not positive).
Old 12-09-2011, 08:44 PM
f6boomer f6boomer is offline
Vehicle: 2003 1500 Qc 2wd
Trim Level: SLT Quad LoneStar
f6boomer is on a distinguished road
Default WOW, Great info
Thanks 440M, that's the best explanation of our trannies I have heard, wouldn't it be nice if someone standing in a dealership could tell you stuff like that!
TP, I think you are on the right track. Since you already have the 3.92 and only tow a few times a year, good maint, a few upgrades to the 4.7, and most important O/D off or Haul mode is the way to go.
Thanks again 440Magnum.
Lord help me, I'm just not Bright, D'OH !
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 02:45 PM
Towing questions 67Polara Towing 8 05-08-2011 01:48 PM
Dodge 1500 not good for towing as advertised. TheDon 2010 Dodge Ram Forum 34 12-30-2010 12:36 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
1997 1500 transmission questions ajay080672 5.2L V8 Specific Topics 3 10-15-2009 10:26 PM
