Old 10-23-2011, 08:31 PM
DodgeGuy85's Avatar
DodgeGuy85 DodgeGuy85 is offline
Vehicle: 1996 ram 2500 4X4
Color: Blue
DodgeGuy85 is on a distinguished road
Well looks like I was able to save the tranny...I went and got fluid,filter again ! and a bottle of Lucas stop slip I know alot of people don't like it or say it's not good to use in these trannys but I said what the hell what could I lose if Its going to blow then it will so figured I'd try it.I adjusted the rear band before putting pan back on,I didnt mess with the front band due to not knowing exactly where it was.I also disconnected the supply line into cooler and flushed all the water out from torque converter,there was a bunch of water still in system finally got it to run clear fluid after putting almost 8 quarts of fluid until it cleared the water. Topped it off and added the lucas and took her for a drive around the neighborhood for like 10-15 mins and it seemed to be shifting fine again it did down shift hard at one point but i think It was just the fluid still trying to work its way all the way thru the system.But it seems to be ok now. I'll know tomorrow what happens when I drive it to work. Thanks again yall for the help on this I am very very greatful ! ~Ronnie~
Old 10-23-2011, 08:43 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Glad to see your effort payed off I hate to see anyone go through that. Good luck for tomorrow let us all know how it did.
Old 10-24-2011, 10:51 PM
DodgeGuy85's Avatar
Color: Blue
Well made it to work ok this morning it was shifting fine and surprisingly smooth.Got to work parked and notice a little puddle of tranny fluid under it.Looked underneath and seen it leaking from the front of bell housing guess the seal inside is shot.Got off work and 95% of the way home was still shifting fine and smooth then 2 miles from the house it didnt want to shift running between 55-60mph it would upshift when I got on it but would'nt shift down in gear to run at that speed and I was in overdrive. Pulled over to check it out and it wouldnt downshift until around 25mph and it downshifted all at once not gear by gear like it should. pulled dipstick, fluid was red and clear and at a good level.Went to take back off and truck would'nt move you could feel it trying but had to give it some gas then finally went.It shifted into second and third but nothing else made it home barely was catching and slipping all the way to driveway, went to turn in and it gave up couldnt pull into driveway tried everything I left it where it was to let it cool down then was able to get it on the driveway.Well needless to say I'm done with it I figured, well I only bought it for $1,500 and its about $12-1,500 to rebuild so made the decision to just borrow a loan from the parents to just get a newer more reliable truck.I can't complain it lasted a good while I've owned it for 2 years and put 15,000 miles on it so I got my moneys worth out of it.Just tired of dumping money into it. Going to strip everything out wednesday and call a junk car place to come pick it up.Going to buy a newer truck sometime this week or by next weekend.I should be able to atleast get $500 out of it since motor still runs strong so we'll see what happens. Any one need parts? LOL
Old 10-25-2011, 11:12 AM
ramfam's Avatar
Trim Level: Base
Rep:21
That sucks sorry bout truck. hope you can find another newer ram!
03' Dodge Ram 1500 4.7L Magnum - TRANNY PROBLEM - Did the shop screw my tranny up? emodpro 4.7L PowerTech V8 Specific Topics 3 09-16-2010 02:53 PM
Blew up my tranny cooler! Fredniner 5.9L V8 Specific Topics 5 06-13-2010 09:04 PM
New tranny and eng. t-stat, but odd temp behavior glostamann 5.2L V8 Specific Topics 1 03-13-2010 02:08 PM
Quick tranny question Excoastie 5.7L (345 cu in) HEMI V8 Specific Topics 4 02-28-2010 03:31 PM
No reverse in tranny YoMoma 5.9L V8 Specific Topics 16 12-08-2009 10:55 PM
