Old 10-21-2011, 10:29 PM
mike49 mike49 is offline
Vehicle: 2009 Dodge Ram 1500
Color: tan
mike49 is on a distinguished road
Default EVIC gas mileage inaccurate
I've taken several (freeway) trips and calc'd mpg by gas purchased/miles driven and the actual is always ~10%-12% less than the EVIC report for the trip.
I see a LOT of people reporting their mpg from "computer" which I assume is the EVIC - is it only my EVIC that is so far off????
Is there anyway to adjust the EVIC mpg figure? It would be nice to have an accurate calculation of Distance to Empty for instance
2009 RAM 1500 w 4.7L, 2WD
Old 10-22-2011, 04:06 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Mines off to usually by at least 1mpg
Old 10-22-2011, 07:31 AM
gshelton777 gshelton777 is offline
Vehicle: 2011 Ram 1500 Sport 4x4
gshelton777 is on a distinguished road
Mine is consistently off 1.5 mpg. Measured mileage is 16mpg, EVIC says 17.5.
Also note that your Distance tilll Empty will plummet when you get down close to empty.
Regards, Glenn
Old 10-22-2011, 08:49 AM
Stagman's Avatar
Stagman Stagman is offline
Vehicle: 2011 Dodge Ram Big Horn 4x4
Trim Level: Big Horn Crew Cab
Rep:54
Stagman will become famous soon enough
Over 6000 miles mine is consistenly off by only .4 in my hemi.
Old 10-22-2011, 07:29 PM
B.Hud B.Hud is offline
Vehicle: 2009 ram
B.Hud is on a distinguished road
never double checked it but think i may start
Old 10-22-2011, 07:43 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
My truck doesnt have EVIC. However it can be effected by the specific gravity of the fuel you use. For instance it will likely be more accurate with G100 than E15.
Gene
Old 10-22-2011, 07:49 PM
EVIC mpg measurements are a dynamic, in the moment, kind of measurement and only show what the current mileage figure is, not a combined mileage figure.
I just calculate my MPG the old fashioned way - Miles traveled / gallons used = MPG
Old 10-23-2011, 10:53 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Rep:209
^^^What Maddog said^^^
Also, the electric fuel pump is cooled by the fuel. As you empty the fuel tank the pump runs hotter/less efficiently. If you tend to run the tank to nearly empty (as I do sometimes) you'll notice that the EVIC and Calculated values will be farther apart. Try only using 1/2 a tank and then fillng it up again and you'll see that the EVIC value won't drift quite as badly.
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
Does Your EVIC Display Instant Mileage? brokenwrench66 2009 Dodge Ram Forum 18 06-14-2011 02:55 PM
EVIC Info - PSI and Instant Mileage brokenwrench66 2009 Dodge Ram Forum 6 05-27-2011 11:32 AM
EVIC and mileage numbers ram4x4 2009 Dodge Ram Forum 8 04-08-2011 11:36 AM
Ok maybe I'm crazy - funny EVIC happening today with mileage hpc3 2010 Dodge Ram Forum 8 06-17-2010 09:39 PM
