Old 10-22-2011, 12:20 AM
Sooner2k1 Sooner2k1 is offline
Vehicle: 2011 Dodge Ram Crew Cab Sport
Sooner2k1 is on a distinguished road
Default Removing Factory Body Bolt for Nerf Bars
I'm having the hardest time removing the factory body bolt on the front driver and passenger sides of my 2011 dodge ram to install the nerf bar body support brack. I'm just using a wratchet. Am I going to be able to accomplish this without some kind of special tool? I'm putting all my weight into it and its doesn't seem to be loosening at all.
Any comments or words of encouragement are appreciated.
Old 10-22-2011, 01:00 AM
vigilante1 vigilante1 is offline
Vehicle: 2011 Dodge Ram Laramie
vigilante1 is on a distinguished road
I had the same issue. I used a friends impact wrench to loosen those bolts. The bolts are buried in tight, so a ratchet wont work.
Old 10-22-2011, 08:53 AM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
When I installed mine I used a ratchet and got them off with a little foot pressure.. there are lock tight on the threads so u have to get that broken away then its all good.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 10-22-2011, 09:17 AM
jtodt jtodt is offline
Vehicle: 2011 Dodge Ram 1500
Rep:38
jtodt is on a distinguished road
Try slipping a piece of pipe over the handle of your ratchet to give you some leverage. Once the lock tite is broke loose it will come out.
Old 10-22-2011, 09:20 AM
Rep:38
Oh yeah, you need to make sure you reinstall the bolt with more lock tite. You don't want it to back out while your going down the road.
Old 10-24-2011, 07:55 AM
JimmyNichols's Avatar
JimmyNichols JimmyNichols is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
JimmyNichols is on a distinguished road
I used an impact wrench to break them loose. I also used my impact to get them back on, left them loose of course so I could level. Then I used my torque wrench to torque them back down.
EDIT: By the way the torque spec for those bolts is 80 ft/lbs.
Old 10-25-2011, 03:31 AM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
try a spray called "Freeze Off", I don't know why, but I broke a Craftsman 1/2 drive rachet when doing my wife's VW rear brakes, I used a pipe extension and a bottle jack and still couldn't budge the bolts, but I did break the rachet...by chance I found this product at my auto parts store, sprayed the same bolts, let them sit for a few minutes, and almost knocked my self out with the rachet handle, as the bolts became instantly loose and so easy to remove....couldn't believe it, it was really like magic....I will never be without a can of this stuff in my garage again.....
So it is written ! So it shall be done!
Old 10-26-2011, 01:27 PM
mikeka mikeka is offline
Vehicle: 2011 Ram
mikeka is on a distinguished road
Isn't Freeze-Off more of a rust penetrant? I think the issue is more of bolts being installed by a gorilla with a impact wrench. I am amazed how tight these guys call install filters.
Old 10-27-2011, 07:48 AM
Rep:27
I don't know what is in it, but it sure made easy work of some factory bolts that wouldnt budge any other way, and that I had put so much force on, my rachet actually broke..... I had my rachet, a piece of pipe slipped over it's handle and a bottle jack under that...bolt wouldn't budge, a littler "freeze off" a few minutes later, the bolts came loose with just a short rachet, nothing else, same on the other side....like I said, it was magical......
Old 11-05-2011, 07:09 PM
HomeGrown HomeGrown is offline
Vehicle: 2005 Dodge Ram 2500 Quad CTD
Color: Bronze
Rep:17
HomeGrown is on a distinguished road
Note to self: see what forum you're in before posting year-specific questions.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 49 02-05-2014 03:02 PM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 05:53 PM
Removing factory exhaust MiStiC NiNja 2010 Dodge Ram Forum 15 02-14-2011 06:37 PM
Need advise for removing factory radio... Chas Body & Interior 2 06-26-2010 09:17 AM
