Old 11-05-2011, 07:34 PM
Rep:2657
I personally use either PB Blaster to remove most hard to unscrew bolts
If that doesn't work i go to the special stuff, KROIL, i picked it up at a gun shop
if that does work, time to add some heat
GM used to have a penetrant that was sold at the dealers Parts Dept., it worked wonders on exhaust manifold bolts
GM 1052627 "General Purpose penetrant and Heat Valve Lubricant".
Old 11-07-2011, 05:06 AM
Stagman's Avatar
Stagman Stagman is offline
Vehicle: 2011 Dodge Ram Big Horn 4x4
Trim Level: Big Horn Crew Cab
Rep:54
Stagman will become famous soon enough
2nd the PB Blaster! That stuff is awesome. I broke two sockets and a ratchet on a bumper bolt on a jeep. Friend told me to try the PB Blaster. Sprayed, waited 15 seconds, off it came....Amazing!!!
Old 08-17-2012, 04:58 PM
bodrie4 bodrie4 is offline
Vehicle: 1995 Jeep Cherokee
Trim Level: N/A
bodrie4 is on a distinguished road
Talking
I could not budge the bolt either! Was about to go get some of that spray stuff, but decided to try again. I got it out by banging my hand onto the ratchet as hard as i could with the little space I had. Once you move it, it comes out fine!
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 49 02-05-2014 03:02 PM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 05:53 PM
Removing factory exhaust MiStiC NiNja 2010 Dodge Ram Forum 15 02-14-2011 06:37 PM
Need advise for removing factory radio... Chas Body & Interior 2 06-26-2010 09:17 AM
