Fan resistor and motor questions/help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-22-2011, 02:22 PM
michicks michicks is offline
michicks is on a distinguished road
Default Fan resistor and motor questions/help
07 Ram 2500 with a cummins
Replaced the fan motor about 18 months ago as it was intermittently going in and out and then only working on high and it fixed the problem. Started the same thing again, this time I checked the resistor and it was shot, replaced and it worked fine for about 5 minutes before the resistor went out. With the key on and engine not running the fan controller works for all 4 speeds, with truck running it only works on high.
Only think I know to do it replace both the resistor and motor again and see if it fixes the problem.
Any other advice
Old 10-22-2011, 04:03 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like the fan motor is faulty and drawing too much current which in turn is blowing the resistor.
brad
Interested in one of my mods?
Old 10-22-2011, 06:36 PM
I had been leaning toward that thought as well, well everything out and hooked it up on the shop table. Fan worked on straight 12v, and on both high and low outputs on the resistor but both the fan and resistor got extremely hot very quickly (especially the resistor)
Yet another temp gauge question snookomatic 4.7L PowerTech V8 Specific Topics 6 10-31-2011 09:55 PM
Electric fan wiring countryb90 Heating & Cooling 5 08-26-2011 01:11 PM
4th Gen elec fan cfm? CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 22 04-07-2011 05:36 PM
Electric Rad Fan panhead LD RAM - General Discussion 10 04-01-2011 02:37 PM
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 03:12 PM
