Old 10-22-2011, 02:33 PM
CamoBoy34 CamoBoy34 is offline
Vehicle: 2004.5 Dodge Ram 2500
Rep:12
CamoBoy34 is on a distinguished road
Default Over heating problem
ok i have a 2005 quad cab 4x4 with the 4.7 obviously and it has an overheating problem. i have changed the water pump, thermostat and bled all the air out of the system and its full of anti freeze and it still runs about 220 degrees. also on a side note i am getting anti freeze into #8 cylinder. i am stumped on what to do so what do you all think is the problem?
Old 10-24-2011, 12:10 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
My guess would be head gasket problem. if too much coolant is getting in the cylinder you will bend a rod so be careful. i dont know a lot about this though wait until more experienced members chime in
Old 10-24-2011, 01:24 AM
icywhite's Avatar
icywhite icywhite is offline
Vehicle: 04 dodge ram
Rep:29
icywhite is on a distinguished road
yep man most likly head gasket the 4.7 are bad about blowing them. esp if you have coolant in the cylinder and it is usely at the number 8 i went though it not to long ago
2/4 drop,h.o. cams,4.56s posi, stage 2 cai, 70mm tb, 180t, cutouts, efan, centerforce dual friction clutch,short throw shifter 24%, sct(tuned by flying ryan), high flo-Y, 3 inch exaust , jbl headers, 2013 intake manifold, nitrous, killian ported heads,leds and hids on all lights,
Old 10-24-2011, 10:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I triple a head gasket issue. Remove the head and replace the head gasket is the fix(a little bit more difficult of a job due to overhead cams....)
Sean
Old 10-26-2011, 11:33 AM
Rep:12
ok thaks for the input i think i will do it over christmas break. now i am goiong to school for john deere mechanic and am pretty good with a wrench. do you think i will be able to pull this apart and replace the gasket without any "special" tools? plus is there anything that needs special attention due to the over head cam?
Old 10-26-2011, 11:38 AM
Rep:12
plus would the head gasket be causing my motor to run hot?
Old 10-26-2011, 02:14 PM
snrusnak's Avatar
Rep:1385
^ I'm not an expert in this subject but if you're losing coolant due to the head gasket then yes you would run hot I'd say.
If your handy it shouldn't be too bad of a job. hardest part would probably be removing the cam, I think you have to remove part of the timing chain, I've never done it on the 4.7L, try PMing superiorstyles he can answer your questions he's done it.
Sean
Old 10-26-2011, 02:38 PM
Rep:2640
a partially blocked radiator could cause over heating
i would replace the thermostat also, the newer ones when they go bad, stick OPEN, not closed like the old style
sticking closed almost guaranteed warped heads
the good thing about the 4.7 & 3.7 engines, is they can be replaced with a new or good used one, you just use the original intake manifold with all the electronics still on it, along with all the original type sensors. That way you don't have to switch out the computers
Old 10-26-2011, 07:58 PM
Rep:12
i just changed the thermostat and the water pump but havent done anything with the radiator yet
Old 10-30-2011, 10:15 AM
Denlevi's Avatar
Denlevi Denlevi is offline
Vehicle: 2005 Ram 1500 4x4
Color: Blue
Denlevi is on a distinguished road
Send a message via Yahoo to Denlevi
Blown head gasket will certainly overheat the engine as the coolant leaks out, and damage that motor if its ran that way. Also X2 on the radiator. Change it of you are not sure, it is worth it in the long run for peace of mind. Some folks will dump stop-leak in the coolant to try to fix a headgasket problem or leak and that can plug the radiator cores. I had overheating issues with an older dakota 5.2L i had purchased used, replaced everything I could think of, thermostat, water pump, fan clutch, and it ended up being the radiator was partially blocked. It was a pain to diagnose because it it still flowed coolant just not enough to keep it cool under load.
2004 Dodge Ram Heating Problem Jacksback Heating & Cooling 7 01-03-2013 10:51 PM
Heating Problem, and Truck Overheating. Related? hockeyplaya13 Heating & Cooling 2 03-14-2011 03:26 PM
heating problem atb1137 Heating & Cooling 10 01-24-2011 02:57 PM
need help with heating and ac problem pattoves777 Heating & Cooling 4 06-19-2010 11:43 AM
Heating problem mike223 Electrical 8 03-04-2010 12:06 PM
