Over heating problem - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-31-2011, 11:43 PM
CamoBoy34 CamoBoy34 is offline
Vehicle: 2004.5 Dodge Ram 2500
Rep:12
CamoBoy34 is on a distinguished road
ok thanks guys. i think i will replace the radiator if it is still over heating after the new head gasket
Old 11-01-2011, 05:55 PM
Singletary02 Singletary02 is offline
Vehicle: 2007 Dodge Ram
Trim Level: Thunder Road
Color: Gray
Rep:13
Singletary02 is on a distinguished road
Just my 2 cents. I had to replace an oil pump on a friends truck. NOT fun at all. The "special tool" you will need goes around the timing chain and is supposed to lock the chains together and keep them from moving. The cams have a little notch in them that the chain sprocket rides on. You will probably need a pair of pliers to help get them back in place and HOPE the timing chain tool doesnt slip off. Dont want to jump timing. But back to the subject. Sounds like a head gasket. The sooner you replace it, the better. You dont want to be rebuilding a complete engine.
Old 11-01-2011, 07:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Overhead cams can be a PITA, but I have come up with a few tricks when working on them: First of all, I have yet to find a OHC gear lock tool that fits and actually works well, so I decided I will just use zip ties for the rest of the jobs I do(did so on the last one and went beautifully). I used the medium sized zip ties to anchor the cam gears in place, just looped them through the gears and anchored them to whatever I could. It doesn't hold it perfectly but close enough. Also, use a white out pen or white out or something similar to mark the chain and gear at a specific tooth at each gear, so if it does slip you can put it back to the same spot....things like this reallllly help save time and work...
Sean
2004 Dodge Ram Heating Problem Jacksback Heating & Cooling 7 01-03-2013 11:51 PM
Heating Problem, and Truck Overheating. Related? hockeyplaya13 Heating & Cooling 2 03-14-2011 03:26 PM
heating problem atb1137 Heating & Cooling 10 01-24-2011 03:57 PM
need help with heating and ac problem pattoves777 Heating & Cooling 4 06-19-2010 11:43 AM
Heating problem mike223 Electrical 8 03-04-2010 01:06 PM
