passenger floor board wet - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 10-22-2011, 04:30 PM
dsol dsol is offline
Vehicle: 96 dodge ram sport
Trim Level: sport
Color: red
dsol is on a distinguished road
Exclamation passenger floor board wet
i got a 1996 dodge ram club cab and the passenger floor board is wet after a rain. i know its gotta be the door seal but i cant find were its leaking at. didnt know if anyone had this problem and knew a solution.
Old 10-23-2011, 11:55 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
do you have roof lights?
Old 10-24-2011, 01:18 PM
Trim Level: sport
Color: red
sure do.. but my brother inlaws 96 doesnt..and he has the same leak and puddle shape as i do. its not the heater core. i know its the door seal somewhere i just cant see a spot where it is messed up.
Old 10-28-2011, 01:15 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default Door seal
If you're convinced it's the door seal, why not just replace the whole thing rather than looking for the one spot?
I've never done this on my ram, but have on other cars. Just seems like the easiest solution to an annoying problem.
Old 10-28-2011, 01:47 PM
Rep:2964
I remember a similar thing happening, but i don't know if it was older or newer Rams
Somewhere up near the top of the passenger door post, there is a drain tube, this tube can get plugged with debris, like leaf fragments. When this happens, people were getting a wet floor. I believe there is another like tube on the drivers side. I don't know if it is on the door or the windshield.
I seem to remember that some people were seeing moisture around the screw(s) holding the inside plastic piece on the door post
Good luck fixing the problem
Old 10-28-2011, 08:23 PM
Trim Level: sport
Color: red
thanks for the info...i will check for this drain tube and if its not clogged will have to look into replace the whole seal
Old 12-15-2011, 06:49 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
I just fixed the same problem on my old 96 ram. it is the third brake light seal. i read about the same problem on ramforumz on newer rams like my 2010, so i thought id check the 96. sure enough when i took out the third brake light there was some condensation in the lens.
once the light is removed, you will see there is a channel that takes any water the passes by the gasket and it is supposed to drain out the weeping drain on either bottom corner of the rear window. That actually deos work on my 96, but here is where the problem lies.
on the interior side of the rear window behind the plastic trim, you will see two holes on either side of the window that actually go into the weeper drain from the third brake light and the water comes in there...unbelievable right! i had this same leak for a year or more on my 96 and blamed the door seal too.
my old 96 (which i just sold to a friend but am helping him get it running again due to a tranny problem) is a space cab. it always appeared that the water would pool on the passenger side floorboard (SOAKING IT). finally this weekend after reading on the forums about the seal problem in the newer rams, i thought i gotta look again. sure enough when we pulled the side panel in therear seat and checked under the plastic trim, the floor was wet all along the passenger floor (under the side window and kick plate) from the back of the cab to the front.
a little urethane or silicone to fill the holes on the interior window side and some clear silicone or a thinker rubber gasket around the third brake light should do the trick! it did for me.
Old 12-24-2011, 03:39 PM
Trim Level: sport
Color: red
thanks, i will look into this after dealing with my horrible wheel bearing :P a thousand thank yous sir
Old 12-24-2011, 08:47 PM
Race1Mopar Race1Mopar is offline
Vehicle: 1995 Dodge Ram 1500
Color: Forest Green
Rep:67
Race1Mopar will become famous soon enough
The problem is the ac drain is clogged. Look under your ram by the passenger tire and there is an opening on the firewall where the ac condensation drains. If it's clogged you can unclog it by blowing air in there. If that doesn't fix it the seal around the tube may be bad and it's just flowing back inside. I took a piece of tubing and connected it to the piece coming out the fire wall, then an immediate elbow, then a tubing draining down and it solved that problem for me. Lots cheaper than replacing that seal.
Good luck and let us know what fixes it.
Joe
1995 Dodge Ram 1500, bored, stroked and breathing fire.
Joe
Old 12-25-2011, 01:00 AM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Vehicle: 1998 in between truck GM 1500
johnnymopar is on a distinguished road
Good info here! I wonder if a similar problem exists with my 98 Yukon which is being retired once my 2012 Ram 1500 arrives. You guys are very knowledgeable, give yourself a pat on the back.
2008 Ram 1500 leans to passenger side! fmycsmith Suspension 6 01-21-2012 11:45 AM
2011 ram 2500 leans to passenger side garyk LD RAM - General Discussion 7 09-15-2011 08:11 AM
Passenger Airbag On/Off Switch DenverRam Electrical 2 02-14-2011 03:56 PM
Passenger Window Error cvfarm LD RAM - General Discussion 6 01-02-2011 12:40 PM
Replacement of front passenger axle on 2002 1500 4x4 w/ the 4.7 bmaca455 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-03-2010 05:23 PM
