Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 10-22-2011, 04:42 PM
dsol dsol is offline
Vehicle: 96 dodge ram sport
Trim Level: sport
Color: red
dsol is on a distinguished road
Exclamation wheel bearing
need to replace my wheel bearings. got a price and all that...and i have mechanical knowledge...just heard from another 2nd gen owner that there a pain even though there a self contained unit. anyone have a good diy or even just a say if its hard or easy.
Old 10-23-2011, 08:14 AM
2kram 2kram is offline
Vehicle: 2000 ram 1500
2kram is on a distinguished road
Had them off twice for various reasons. First time was a PIA. When you put it back together USE anti-sieze, every time it's been off since they came off w/o having to cuss at it.
Old 10-23-2011, 09:55 PM
Trim Level: sport
Color: red
is it a contained unit? like will i have to replace the whole hub assembly or can i just buy and install a new wheel bearing?
Old 10-23-2011, 10:37 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I believe the 44s bearing just bolts on with 3 bolts to the axle shaft. Shouldn't have to replace the hub. I like to put new axle u joints I while I have it apart
Old 10-24-2011, 01:21 PM
Trim Level: sport
Color: red
do u happen to have pics? cant find a diy anywhere for it. really wanting to see a few pics of the process though before i start tearing it apart in the drive way lol
Old 10-29-2011, 09:47 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I don't know if this will give you the correct url, but this is a pretty basic article. Hopefullly I won't be chastised for doing this.
http://www.pavementsucks.com/tech-article-5.html
If your ball joints haven't been done recently this is a good time to do them as well. And the first time is a TOTAL PITA so have lots of penetrating oil and presoak the crap out of stuff and use lots of never sieze when reassembling the unit bearings in the hubs.
I did mine for the 2nd time last week and they popped right out.
The hub nuts are the toughest things to do if they are rusted. Get a 3/4 breaker bar or a HD air wrench and prepare to break the bar Soak them liberally with a GOOD penetrating oil (not WD-40) and start a week early.
You will need a good press if you do the ball joints and a torque wrench to set everything right, especially the hub nuts.
I would do the u-joints as well if they are rusted or no greasable. DO NOT use cheap azz auto store parts. Only buy spicer joints. You will thank yourself later.
Old 10-30-2011, 08:21 PM
Trim Level: sport
Color: red
thanks so much okie...saved my life..i will hopefully be able to do all this one weekend..looking to do wheel bearings, break pads, rotors, and possibly front u-joints all in one shot
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 165 02-18-2016 08:35 PM
excessive tire wear on front tires Bamboo Dodge Ram Wheels And Tires 5 10-20-2011 07:50 AM
Replaced Bent wheel bearing... ramvan2500 Dodge Ram General Discussion 2 05-06-2011 03:05 PM
Wheel bearing failure? babylacyjane Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-23-2011 05:34 PM
wheel bearing and clunk! Quiet Lunatic Suspension 6 12-25-2010 09:44 AM
