help stuck with bank 1 running lean - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-22-2011, 07:55 PM
clemclark clemclark is offline
Vehicle: 1999 dodge ram
Trim Level: sport
Color: sport
clemclark is on a distinguished road
Exclamation help stuck with bank 1 running lean
ok im stuck and spinning i change plugs rotor cap and plentum gasket and now getting code that that bank 1 is running lean still but notice when gets to running temp it acts like it wants to stall and a poppin sound like a backfire sound but not as loud though motor runs like its almost starving for fuel any suggestions please... before any work was done was getting rapid misfire 1,2,3 and bank 1 running lean after work done only getting bank 1 running lean any help will be highly appreciated thanks
Old 10-22-2011, 08:23 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Did you reset computer?
Old 10-22-2011, 08:51 PM
Trim Level: sport
Color: sport
yes reset with code reader but comes back on after running for few minutes
Old 10-23-2011, 12:51 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
My guess would be that your upstream O2 sensor either got smashed, wire got burned, or is simply disconnected. of course it could be the downstream sensor, but me thinks you would have already looked at that one??
Old 11-10-2011, 10:07 PM
jus Bob jus Bob is offline
Vehicle: 1998 Dodge Ram 1500 4x4 (5.9L)
Color: Dark Brown
jus Bob is on a distinguished road
Default ..." lean condition " " bank 1 " Code
...just incase you havent got your problem fixed ..... I jus went thru the same situation with my 98 5.9 360ci. and it was the oxygen sensor. You should have 2 , 1 in front of the Cat. (upstream sensor) and 1 after the Cat. (downstream) . I changed them both because i have 177k on the odometer and it set me back 120 bucks. There is a 12in. lead extention sensor and an 18in. lead ext. sensor. So you need to figure out which one you have before you do like i did and go to Advance Auto and when they asked which one i had ...i said...HeLL ! jus gimme the 12in. one....it'll work. Well...it didnt. lol Anyway ....truck runs like a champ now and gets BETTER mpgs.
error code list moparmike07 Dodge Ram Knowledge Base 17 12-01-2017 11:12 PM
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 02:52 AM
Rear Truck Lean roar84 Newbie Checkin! 13 05-26-2011 11:59 PM
Running rich or lean 08Ram1500 Diablo Predator Questions & Info! 6 10-29-2010 08:39 AM
Square Testicles at the Royal Bank of Canada. iRESQu Jokes/Humor 15 10-28-2010 11:32 PM
