Old 10-30-2011, 11:03 PM
kslongrider kslongrider is offline
Vehicle: 2001 Dodge Ram, 1996 Dodge Ram
Trim Level: Sport and Laramie
Color: Black Sport, White Laramie
kslongrider is on a distinguished road
And if you were close I'd let it make your day. Wiring issues drive me to distraction.
Old 10-30-2011, 11:04 PM
When I replaced the plug I did one wire at a time so as not to mix up the placements. I'm pretty sure I got that part right.
Old 10-30-2011, 11:07 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
If possible, find a similar truck at an auto wrecker....or a friends and see if you can verify the wiring. Take a camera and take pix from all possible angles so you can refer to them later.
brad
Interested in one of my mods?
Old 10-30-2011, 11:11 PM
Good idea. Thanks. Will do.
Old 10-31-2011, 12:02 AM
brad12kx's Avatar
Rep:2581
I just found some information on the 1996 headlight switch, complete with light switch connector information.....as in all 9 wires.
Pin B2 has the Pink/Red wire and in in the center of a longer side. It has pin D to the right and B3 to the left.
In front of B2 (an off to the side a bit) are -
H - (Tot he right side) with a Light green wire
P - To the left and angled with a Light green / white wire
Further in front (at the opposite side of the connector) is pin R with the Black/Yellow wire. This is the park light feed wire.
Does this sound like what yours is?
BTW, I didn't cover all the wires, just enough for you to get reference to the angle I'm looking at it.
brad
Old 10-31-2011, 12:44 AM
brad12kx's Avatar
Rep:2581
Here is a pic/drawing of the connector showing the wire colors and terminals -
brad
Old 10-31-2011, 06:52 AM
Thanks Brad. Yes that's the one. I will double check the wiring this morning.
Old 10-31-2011, 07:23 PM
brad12kx's Avatar
Rep:2581
How'd you make out?
brad
Old 10-31-2011, 10:07 PM
Picked up a new Mopar switch from the Dodge dealer this afternoon. Just got home and will put it in first thing in the morning. Keeping fingers crossed...
Old 10-31-2011, 10:36 PM
brad12kx's Avatar
Rep:2581
Now the suspense is killing me.
brad
Airbag, ABS, Brake, No Speedo, No reverse lights, No HVAC output selction Thevman Electrical 9 10-30-2013 12:36 PM
stereo issue on 99 3500 Jrob7106 Electrical 4 10-21-2011 12:29 AM
2004 dodge 3500 throttle issue? ladnerbc3500 Cummins Diesel Specific Topics 1 04-05-2011 08:24 PM
HID issue that needs fixing FAST please Quiet Lunatic Dodge Ram General Discussion 3 03-16-2011 01:20 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
