Old 11-01-2011, 01:51 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I vote yes on the does it work now bet.... I don't see how it could be anything else!!
Old 11-01-2011, 01:23 PM
kslongrider kslongrider is offline
Vehicle: 2001 Dodge Ram, 1996 Dodge Ram
Trim Level: Sport and Laramie
Color: Black Sport, White Laramie
kslongrider is on a distinguished road
Well, I've been messing with it all morning. A new Mopar switch and pigtail with matching color coded wires went in and still have the same symptoms. So I went underneath and unplugged the 2 plugs behind the driver's fenderwell that connect to the wiring for the back of the truck thinking if there was a problem in the wiring I'd see if that made any difference. No difference. I despise wiring issues.... Its obviously not a switch issue though.
Old 11-02-2011, 01:12 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
OK....lets forget everything that's been done so far, and start over fresh.
1st - Need to verify the switch operation. Do you have an 'Ohm' meter?
Disconnect the switch from the wiring and we will run some tests on the switch itself.
Using the 'Ohm' meter,
Place one lead on the 'B2' terminal, and the other lead on the 'R' terminal
What are your readings under the following conditions -
Switch in 'Off' position -
Switch in 'Park' position -
Switch in 'Headlight' position -
brad
Interested in one of my mods?
Old 11-02-2011, 01:16 AM
brad12kx's Avatar
Rep:2581
If you don't have an 'Ohm' meter, let me know what electrical test tools you have available to you, and I will figure out how to run the tests using what you have.
Hopefully we can connect on-line at the same time and can do this through 'Chat', as that would speed things up.
brad
Old 11-02-2011, 01:18 AM
Color: 1 Blk,1 Red
Rep:36
Hmmph. I've never been much of a gambler. The only thing I can think of is to depin your light switch connector, one pin at a time. Also, I do not believe the headlight switch operates without a relay, or two. one of them had to have fried, and is not transferring contacts properly. problem is, I do not have a diagram that says anything about a relay. It doesn't make sense that they would run all the power thru the switch, it's too 70s-ish. Wiring costs money, and a relay right close to the battery would save time and weight in wiring. I hope when you find the problem, that you will post!!!
Old 11-02-2011, 01:53 AM
brad12kx's Avatar
Rep:2581
No relays in his truck for this circuit. The physical switch handles all the current for the lights. There have been a number of trucks of this year that have had the light switch connector melt due to this. I agree it's so 70's...but it is what it is. The circuit is so basic, it's sickening....that's why it just doesn't make sense. The problem keeps pointing at the switch, but he's now replaced the switch 5 times! I can't believe it's the switch anymore, but have to run the basic tests on it to verify once and for all that the switch is actually switching the terminals that we are expecting the switching to take place on.
BTW - I have the complete wiring diagram for this; probably one of the worst circuit diagrams I've ever seen, but at least all the information is there....spread randomly over many pages. LOL
brad
Old 11-02-2011, 10:06 AM
I am at work today but will start on this when I get done with chores this evening. I do have an ohm meter so we can run these checks.
Thanks for hanging in there.
Barry
Old 11-02-2011, 10:40 PM
Looking at the terminal drawing, I don't see an R terminal and I don't see one labelled on the switch either. Barry
Old 11-02-2011, 10:48 PM
Okay assuming the R terminal is beside B2, as in pink/red wire and yellow/black wire. So with the switch unpluged when I pull to the park position and headlight position the meter reads around .4. In the off postion it reads 1.
Old 11-02-2011, 11:04 PM
brad12kx's Avatar
Rep:2581
The R terminal is across the connector from B2. Here is the drawing -
Since different meters display differently, I need to know what yours displays when the leads are not connected to anything. I'm expecting something like "1---".
brad
Airbag, ABS, Brake, No Speedo, No reverse lights, No HVAC output selction Thevman Electrical 9 10-30-2013 01:36 PM
stereo issue on 99 3500 Jrob7106 Electrical 4 10-21-2011 01:29 AM
2004 dodge 3500 throttle issue? ladnerbc3500 Cummins Diesel Specific Topics 1 04-05-2011 09:24 PM
HID issue that needs fixing FAST please Quiet Lunatic Dodge Ram General Discussion 3 03-16-2011 02:20 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
