Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-02-2011, 11:40 PM
kslongrider kslongrider is offline
Vehicle: 2001 Dodge Ram, 1996 Dodge Ram
Trim Level: Sport and Laramie
Color: Black Sport, White Laramie
kslongrider is on a distinguished road
The meter reads 1 . when the leads are not hooked up to anything.
Old 11-02-2011, 11:53 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Which is the same reading you get across B2 and R with the switch off....?
brad
Interested in one of my mods?
Old 11-03-2011, 12:02 AM
That's correct.
Old 11-03-2011, 12:03 AM
Just slipped the switch back in, have to leave for work at 5:00am.
Old 11-03-2011, 12:06 AM
brad12kx's Avatar
Rep:2581
Then your reading verify the switch is good.
When you get a chance, with the switch disconnected, using a fairly heavy wire, jump between the Pink/Red and Black yellow wires at the connector. This should turn on the tail markers, etc. Basically, the switch creates a short circuit in the on position that jumps these wires together.
brad
Old 11-03-2011, 05:04 PM
Will do this afternoon when I get home.
Barry
Old 11-08-2011, 01:07 AM
charlesleviparks's Avatar
charlesleviparks charlesleviparks is offline
Vehicle: 1997 Dodge Ram SLT
Color: Green
charlesleviparks is on a distinguished road
I have a 97 1500. I had the same problem except my switch completely melted. After Ohm testing and several switches being burnt (along with the thicker green wire) I just ran new headlight wires and two toggle switches. I hope you get your truck figured out.
Old 11-29-2011, 06:45 PM
Well finally back to working on this mess. In my case the headlights work as they should, its the clearance lights that are messed up.
To answer Brad: doing the jumper wire as you instructed I can make the headlights come on and the marker lights come on. I kinda figured they would since I can get the clearance lights on with the switch but they don't come on when the switch is in the correct position.
I had to drive it out to Rock Springs Wyoming to pull home my 01 with a bad transmission (luckily still under warranty). I could get the clearance lights on in between stops on the switch and by pulling the turn signal handle back and wedging a piece of paper to hold it the headlights would stay on high beam so I had headlights. What a riggin!!! Luckily the lenses on my headlights could use polishing so they don't shine too bright. I may be leaning towards a toggle switch for the clearance lights if I can't get this thing figured out.
Old 11-29-2011, 09:25 PM
sixwheeler sixwheeler is offline
sixwheeler is on a distinguished road
I have run into this same problem and when the dash and running lights turn off, I can hit right above the light switch/dimmer and the lights come back on. So I am completely lost.
Old 11-30-2011, 03:10 AM
brad12kx's Avatar
Rep:2581
Originally Posted by kslongrider View Post
......To answer Brad: doing the jumper wire as you instructed I can make the headlights come on and the marker lights come on. I kinda figured they would since I can get the clearance lights on with the switch but they don't come on when the switch is in the correct position........
Are you saying that when you had the switch removed, and placed a jumper between the Red wire in B2 and the Black/Yellow wire in R that both the headlights and tail/marker/clearance lights came on!
With that jumper in place, ONLY the tail/marker/clearance lights should have lit up. The headlights should have remained dark.
brad
Airbag, ABS, Brake, No Speedo, No reverse lights, No HVAC output selction Thevman Electrical 9 10-30-2013 01:36 PM
stereo issue on 99 3500 Jrob7106 Electrical 4 10-21-2011 01:29 AM
2004 dodge 3500 throttle issue? ladnerbc3500 Cummins Diesel Specific Topics 1 04-05-2011 09:24 PM
HID issue that needs fixing FAST please Quiet Lunatic Dodge Ram General Discussion 3 03-16-2011 02:20 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
