Old 10-23-2011, 01:50 AM
85buggy's Avatar
85buggy 85buggy is offline
Vehicle: 2011 Dodge Ram 2500
Color: Omaha Orange
85buggy is on a distinguished road
Cool Something Burning smell ???
Has anyone had a smell like hot plastic from their truck. Most of my driving is highway so the truck gets hot and I noticed this odor that I can't locate where its coming from other then from under the truck. I've checked along the exhaust that diesel exhaust is big I can't see where it comes in contact with anything, my CB antenna coax isn't making contact with the exhaust. I've thought maybe the factory bed liner got on the exhaust some where . But I have 6300 mi on it I would think whatever is burning should be burnt up by now. The only other thought is that this diesel doesn't have the same smell as my previous 3 diesels, 2 Fords 1 Chevy.
Old 10-23-2011, 02:29 AM
HenryG's Avatar
HenryG HenryG is offline
Vehicle: 2011 Dodge Ram 1500
Color: Grey
Rep:17
HenryG is on a distinguished road
Not too sure about this as I don't have a diesel, but a lot of manufacturers of low emission diesel engines are using an additive to reduce pollutants. I know that the Fords and VW's are doing that but not sure about other manufacturers. Anyway, point is that this may be the source of the unfamiliar odors. Just a thought.
Old 10-23-2011, 06:49 PM
Hedghawg71's Avatar
Hedghawg71 Hedghawg71 is offline
Vehicle: 2011 Dodge Ram Express
Rep:21
Hedghawg71 is on a distinguished road
I know on both my wife's and my truck when I first got them there was a "burning" smell from them after driving them a while. The dealership said it would go away so I started looking under my wife's truck as soon as she climbed out of it after driving it for a while when we first noticed it and it turned out to be stickers all over the exhaust and some were on the heat shields where the resonators are as well. After they all burned off after a couple/three weeks of driving around we don't smell it anymore. This was also true of my Express as well. That being said I would look underneath as soon as you throw it into park after driving it for a while and look around to be sure. They are made of a thick plastic material and will be smoldering.
Nothing a Hammer can't fix!
Old 10-23-2011, 09:05 PM
Willbrewer Willbrewer is offline
Vehicle: 2011 Ram 1500 Hemi QC 2X4
Trim Level: SLT- Luxury&Security
Rep:28
Willbrewer is on a distinguished road
I had a 2010 CTD for a year (bought new) and I noticed the same smell at times when it got up to good operating temp for a while. It was kind of a burning plastic smell, like you said.
It's a common occurrence with the CTDs, and it goes away after a while. I started noticing it after a couple thousand miles of driving. It was most noticeable when I stopped the truck during a regen cycle, which is when the extra shot of fuel goes into the cylinders to heat up and burn off the soot in the DPF.
It's not a problem, and once all the "new" burns away, the smell will go away too.
Bill
Old 10-23-2011, 09:15 PM
85buggy's Avatar
Color: Omaha Orange
Default Smell ?
isn't there some indicator light for the regen cycle I haven't seen any yet. But glad to see someone else has had this same thing ..Thanks
Old 10-23-2011, 11:23 PM
Rep:28
No indicator for most regens, unless you get the message "DPF 80% Full" when you're supposed to take it on the highway for 45 minutes or so. I never got that message on my 2010, I think because I used it mostly for towing, and rarely used it as a grocery getter.
The only indication of the passive regens is seeing the lie-o-meter miles per gallon reading drop by a few digits. I noticed a minor lack of power at times while towing too.
Bill
Old 11-15-2013, 10:18 AM
LaramieNL's Avatar
LaramieNL LaramieNL is offline
Vehicle: 2013 Ram Laramie Crew Cab
Trim Level: Laramie Crew Cab
Color: Steel Metallic
LaramieNL is on a distinguished road
I have been noticing the smell of burning oil/rubber on my 2013 Laramie lately.. It seems like it coming from underneath the truck as it is strong between the cab and the box. The truck has 12000 kms on it so I am convinced that it is not from stickers on the exhaust system as mentioned in previous posts. Anyone have any answers on what may be the cause of this?
Old 11-15-2013, 04:30 PM
Trim Level: sport
Color: green
Rep:652
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
there have been reported smell issues with the hoses.
Rubber burning smell ronald koons 5.9L V8 Specific Topics 5 08-10-2011 09:09 PM
remote start and smell of burning jerzy1283 2010 Dodge Ram Forum 5 07-17-2011 01:40 PM
Problem: Coolant smell from engine but no smoke or water in oil (see pics) elektromaniak Heating & Cooling 7 06-04-2011 08:50 AM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
burning smell on new muffler FDBDW 2009 Dodge Ram Forum 4 07-21-2010 08:51 AM
