Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-23-2011, 01:36 AM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
Default anti gel? lift pump?
Hey guys my first diesel (2000 5.9) so I'm pretty much clueless my questions are these
1- at what temperatures do you have to start adding anti gel ?
2- It appears that the lift pump is a week link how many miles can you expect to get out of one? does it go bad all at once? what are some symptoms? are remans ok?
Thanks for any info you may provide
Old 10-23-2011, 02:22 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
The temperature actually depends on the blend of fuel and it's additives. Some fuels cloud point (Fuel starts appearing cloudy which is the formation of wax) can be as high as 20-40*F. It's hard to say what the cloud point of the fuel you use is but your stations usually start switching to a winter blend within the next few weeks. We have a 300 gallon fuel tank that has had "summer" blend thats hit -7*f with out starting to cloud.
Don't really know much about lift pumps though
Old 10-23-2011, 10:24 PM
Thanks for the info does that mean with the winter blend I don't need to add any additives
Old 11-11-2011, 01:52 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Id add ant gell even with winter blend for temp below 25° and lower. As for pump it will start to Loose power be hard to start, surge under power. Trust me it sucks when your driveing a 24,000 lb. straght truck and your lift pump goes out. And yes its a 5.9 cummings.
Old 11-11-2011, 01:55 PM
ramfam's Avatar
Trim Level: Base
Rep:21
As far as life on it the one in the co. truck whent out early in life, so it just depends.
Old 11-11-2011, 02:07 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Another tip I dont know about the dodge but our co. truck's go thru fuel lines frequently. But I still sware by them especially in a pick up. They can pull more then the truck is built to do! Trust me I pull 8 to 10,000 daily.
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 06:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 10:25 PM
New inj pump, now lift pump does'nt work Stewartforever Cummins Diesel Specific Topics 5 08-27-2010 02:43 PM
In-Tank Bosch Lift Pump Specs Old & Injecting Cummins Diesel Specific Topics 0 12-15-2008 03:33 PM
