Old 10-23-2011, 07:22 AM
BJPUSMC's Avatar
BJPUSMC BJPUSMC is offline
Vehicle: 2013 Ram 2500 Mega Cab 4x4
Color: Deep Cherry Red/ Silver
BJPUSMC is on a distinguished road
Default Bilstein 5100 with 6" Suspension Lift Question
I have seen quite a few people on here with 6" suspension lifts that have also added the Bilstein 5100s to add another 2 inches of lift. I am curious as to how tis is working for you guys considering ( at least in my case with the Pro Comp lift) that the lift actually adds 6in in front with 4 in the back leveling out the truck. Its seems the Bilstein's adding the addition lift in front would give it a front high stance. Am I missing something here?
I know a lot of these people here have posted pics of their lift but our internet restrictions out here seem to filter or block most of the posted pictures from displaying so I havent been able to see for myself.
i ask because its seems my lift installed for some reason is about an inch shorter than most other lifted 4th gen 1500s that I have come across, even compared to those with the same Pro Comp lift. So I woudlnt mind getting an addition 2 inches out of it with out risking excessive wear on my CV joints.
Thanks for any advice/input you may have with this.
2013 Ram 2500 Laramie Mega Cab 4x4,
6.7L H.O. Cummins Turbo Diesel
USMC Pilot
Old 10-23-2011, 11:57 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Well I have a 6/5" BDS kit with Bilstein 5100's set at 2.8". Min had a 3.5" rake when it was stock. I got the 5" rear so my truck nose dived. Now I have about a 1" rake which i am fine with. My truck is riding so much better and I don't have any problems.
Old 10-23-2011, 12:33 PM
BJPUSMC's Avatar
I just double checked and actually the Pro Comp is a 6/5" also (been about a year and half since i installed it and a few months since i have actually seen my truck). Did you just add the 5100's up front or all around? Could save a few bucks if I kept the Pro Comp Shocks in the rear, especially since I will be adding airbags back there.
USMC Pilot
Old 10-23-2011, 12:57 PM
Rep:463
You can't put the 5100's on the rear they are struts. So just keep your rear shocks. I am going to go with the 7100 Bilteins later for the rear. They have 14" of travel.
Old 10-23-2011, 02:30 PM
BJPUSMC's Avatar
Ok. I know they have the 5100 non adjustable shocks for the rear which is what i was referring to but that answers my question. Thanks. One other question for you. Those Lamin-X blackouts you have, do they degrade you headlight performance much?
USMC Pilot
Old 10-23-2011, 02:41 PM
Rep:463
Nope I see fine with them on there.
Old 10-23-2011, 02:44 PM
BJPUSMC's Avatar
Thanks. yet another addition on the list of mods to be performed upon my return stateside.
USMC Pilot
Old 10-23-2011, 08:46 PM
Rep:463
Well it is a good mod. I love mine!!
Old 10-24-2011, 05:06 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
OP, if you max out those Bilstiens at the 2.8" setting. Your only gonna gain 1"-1.3" of height.
[CENTER][SIGPIC][/SIGPIC]
Old 10-24-2011, 05:15 PM
Rep:463
I got more then 2" of hight with mine set at 2.8" bro. I had a 1" spacer in the front. I took it out put the bilsteins in and it went up 1.4" from the 1" spacer.
Bilstein 5100 adjustable leveling question?? ramsport10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 07-30-2011 08:13 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
One last question on the Bilstein 5100 shocks MAXX25 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-05-2011 12:44 PM
One last question on 5100 bilstein shocks MAXX25 2010 Dodge Ram Forum 2 12-29-2010 08:01 PM
6" lift compatibility questions xopt1js Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 12-04-2010 12:54 AM
