Old 10-24-2011, 08:06 AM
mntnbkr1968 mntnbkr1968 is offline
Vehicle: 2002 1500
Trim Level: southwest
Color: silver
mntnbkr1968 is on a distinguished road
Default Wife is warm, I'm cold!!
Hello everyone!
I've searched and found similar complaints.
So what gives on my 2002? Why is there hot air on the
passenger side and cold on mine? (dash vents)
TYIA
Monty
Old 10-24-2011, 03:27 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
As long as the wife is happy, I wouldn't worry about it... But, seriously, sounds like you might have some blockage in your vents. Have you had a rodent problem at all? They like to get in where it's nice and warm and build their nests... Just a thought.
Old 11-17-2011, 06:37 PM
whipinalluponya's Avatar
whipinalluponya whipinalluponya is offline
Vehicle: 2002 dodge ram 1500
Color: graphite gray
whipinalluponya is on a distinguished road
NOOOOOOOO. ohhh its like telling someone they have cancer. i have researched a/c heater problems when my recirc door went out. what you have is a blend door issue.
the blend door is controlled by the little blue/red knob or slider if you have dual zone, which if you do that means you have two blend doors which is worse...... anyway getting to the point the fix involves taking the entire dash out(almost impossible RAM you dodge!!) then you have to take out the a/c heater after draining it and disassemble the plenum then put in new blend door(s).
I hope i am wrong and i hope you don't have to experience what i have read about..... good luck on this man, really.
I got to use my AK........... today was a good day.
Old 11-18-2011, 08:14 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you test the Heater/AC controls on the dash?? I'd look at the dual zone control first and make sure you're getting power out the driver's side control. I work in a scrap yard and that's the second thing we sell...first is the cup holder.
Old 11-19-2011, 03:23 AM
Rep:2657
take a look at the website www.heatertreater.net
2002 - 2008 dodge ram
http://www.heatertreater.net/dodge-ram-02-08
if you have the earlier 2002
http://www.heatertreater.net/dodge-ram-95-02
watching the videos may answer your questions, but they also have a write up
all together there are 3 YOUTUBE videos covering the Ram
but several other Youtube sites cover the issue too
Good Luck
Old 11-19-2011, 07:36 PM
That's a great find, GT!
Old 12-02-2011, 11:50 PM
NC4Life078 NC4Life078 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 4x4
Color: Bright Metalic Silver
NC4Life078 is on a distinguished road
Hey man check out my thread maybe we can help one another. I have same problem with my 02, I posted in the newbies section like a tool. I thought it was the blend doors too but its turning out not to be ne ways hit it up...
http://www.ramforumz.com/showthread....ght=blend+door
Old 12-07-2011, 08:06 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Make her drive.
Problem solved.
Sure it'll suck, but it'll make you a man
Old 12-29-2011, 10:43 AM
Exclamation Problem Solved
Originally Posted by bigdaddyII View Post
Make her drive.
Problem solved.
After I found out it wasnt the blend door, thermostat, fluid, I figured it was the heater core. I took it to a mechanic and had them flush it, It solved the problem and cost $43.00. I'd suggest trying this first before you do the rest.
Old 12-29-2011, 06:34 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
You can flush the heater core yourself. Just undo the hoses leading to the heater core, on my truck they were both on the passenger side valve cover, just simply unclamp and spray both ways with a garden hose till the water runs out clear. You can also grab a funnel and dump a bottle of mean green or some other all purpose cleaner in there if you are so inclined.
AC blowing cold on one side and warm on the other Bhoman10 Heating & Cooling 19 07-31-2014 05:39 PM
POS messing with my wife.... USMCLcpl0311 Off Topic Discussion 33 09-06-2011 08:41 PM
Great cold starts... not so much warm Bruno72 5.7L V8 Specific Topics 5 03-24-2011 10:24 PM
The Obedient Italian Wife! Toms Blue Ram 1500 Jokes/Humor 5 08-06-2010 12:17 AM
