United Radio
Old 10-24-2011, 12:56 PM
sandman57 sandman57 is offline
Vehicle: 2001 dodge ram
Color: blue
sandman57 is on a distinguished road
Default oil pressure
I have read some threads on this site that r alot like the problem I'm having.When I start my truck the oil pressure is fine but once the truck is warm and is at idle the oil pressure gauge goes to 0.When I give it some gas it returns to normal pressure.The truck does not run hot and the motor does not make any rattling sounds. Its done this the last 5 or 6 times I've started my truck.I owned a ford many years ago and the pressured gauge started going up and down then when to 0 ,with a few min. the motor started raising h**L so I know what this sounds like.This seems to be different.I replaced the oil pressure sending unit 2 years ago and change my oil after the first time my truck started this(last fri).Could I have a bad dash gauge,something clogging up the in the oil pan or oil punp going bad?
Old 10-24-2011, 01:14 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Take out your oil sending unit and tee in a fitting so you can run a mechanical gauge, then check your readings. You may indeed have a bad dash gauge, bad wiring, or bad sensor.
Internally, the oil pump could have excessive wear. If you try a thicker oil, and the pressure increases, this is another area to look at.....
Old 10-24-2011, 03:06 PM
Color: blue
I talked to mechanic that I know and trust (hard to find those around here)that he's never seen a oil pump just go bad.They may get clogged and stop working. Because they r aways lubed by the oil.He said it could be a bad gauge or sending unit.or something internal in the motor.That dont sound good
Old 10-24-2011, 03:11 PM
Rep:24
Just because he's never seen an oil pump go out doesn't mean they don't. No disrespect meant towards your mechanic, but it does happen, Also, oil pumps can wear out- a sign is that your pressure is low/non-existent at idle, but indicates on the gauge under load. Excessive bearing wear (which equals excessive clearance) shows the same symptoms.
Old 10-24-2011, 04:12 PM
Color: blue
Ok,I'm trying to learn and do somethings for myself because I got more time than money.Plus the more u know the better off u r
Old 10-24-2011, 11:26 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
First thing I would do is what SeattlePete recommended in his first post....'T' in a mechanical guage.
brad
Interested in one of my mods?
Mechanical oil pressure gauge install 440Magnum 4.7L PowerTech V8 Specific Topics 2 01-28-2014 09:51 AM
Oil pressure gauge installED.. 440Magnum 4.7L PowerTech V8 Specific Topics 1 07-08-2011 08:15 PM
Oil pressure question Wolfwasp 5.2L V8 Specific Topics 21 06-26-2011 02:31 PM
2003 Ram 1500 5.9L Oil Pressure Jibby Electrical 1 05-20-2011 02:58 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
