Old 10-22-2011, 07:49 AM
facehugger facehugger is offline
Vehicle: 2010 Ram Laramie cc rambox
Color: brillant black
Rep:29
facehugger is on a distinguished road
Default Error after TB installation
This is really strange, after i installed the 90mm arrington tb i get following code:
P0507
Idle Air Control System RPM Higher Than Expected
I was looking around and saw it could be one of the following (or more) things:
  • A vacuum leak
  • Leaking air intake after the throttle body
  • EGR valve leaking vacuum
  • A faulty positive crankcase ventilation (PCV) valve
  • Damaged/failed/dirty throttle body
  • Failed EVAP system
  • Failed IAC (idle air controller) or faulty IAC circuit
Well i remounted now the third time the tb and im really sure everythings well installed, not leaking and NOT dirty.
Every time i installed or reinstalled it, i was disconnecting the battery for over 30 mins.
Does anyone has a clue why this could be?
2010 crew cab Laramie RamBox
Recon smoked headlights, taillights & 3rd brake light - tribal Grille insert - grille blacked out - Gibson catback split exhaust system - oval premium side steps - spray in bedliner - Diablosport Trinity 93 oct tune - air deflector chrome style - Volant CAI - carbon dash kit - interior LED replacements - Arrington 90mm tb - Bakflip
Old 10-22-2011, 09:51 AM
Rep:29
could slap myself
i'm not sure but im pretty sure this was the point
seems like after cai install the tube to the iacv was buckled so of course he was getting more air as expected
didn't realized that somehow because the tube system doesent really match perfect with the engine cover, so i took the cover off now .
Old 10-22-2011, 11:01 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
yup..looks like you got it...
Old 10-22-2011, 11:09 AM
Rep:29
yeah i guess so, but i have to check this while drving around half an hour later.
the code was never coming immediatly
Old 10-23-2011, 05:28 AM
Rep:29
Well the message comes back again
Noticed again a high idle rpm in "P/N" around 900-1000 rpm.
Anyone got an idea where to search further?
Old 10-23-2011, 12:26 PM
DAYTONA81's Avatar
DAYTONA81 DAYTONA81 is offline
Vehicle: 2005 dodge ram
Trim Level: Daytona
Color: go man go
Rep:108
DAYTONA81 will become famous soon enoughDAYTONA81 will become famous soon enough
I might have to take my cover off then cause my still have that pinch on the hose
2010 DODGE RAM CC 5.7L- MAGNAFLOW ONLY
2005 RAM DAYTONA- 426 HEMI
Old 10-23-2011, 12:55 PM
Rep:29
yeah but this didn't changed anything to the OBD msg - it's still coming.
Now i reinstalled my oem tb and see how it goes.
I heard something that with new tb has to be done a "relearn" procedure... but im not sure of that.
but im really sure i checked almost everything mechanical related to this part and the only logical solution for me would be:
- busted a sensor while mounting
- the truck doesent realizes really the new situation with maybe a bit more open tb-blade
- it doesent corrects well the new airflow situation
can't figure out something else, but i realized now the difference btw. stock and 90mm arrington - makes about 0,3 - 0,45 secs in the 0-60 mph run
response is also much better with the aftermarket.
Old 10-23-2011, 11:21 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
a 90mm TB is fairly large for a stock engine. You might just be sucking in more air through the TB with it cracked open for normal operation.
I know a lot of cars when you increase TB size like that you get error codes like this.
just food for thought
2011 Big Horn 4x4 -SnowWhite-
Old 10-24-2011, 12:16 PM
Rep:29
well i tried the "old" one back and no more obd's
but someone told me a new tb should get through a "learnprocess" which can be made with a starSCAN tool, but as i found they're kinda expensive
3000-8000 bucks is kinda heavy for such a thing
Old 10-24-2011, 02:15 PM
Rep:29
oops d-post sry
U connect installation for RES radio merk440 4th Gen UConnect 11 03-10-2014 08:14 AM
Projector headlight HID installation help Niko Custom Dodge Ram Interior and Exterior Lighting 10 01-23-2012 07:49 PM
Rollbak on the way - any installation tips/secrets? californiajed Dodge Ram General Discussion 3 10-28-2011 12:11 PM
Katzkins Leather Seat Upgrade Installation Write-Up Part 1 DoubleARS Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 11-29-2010 08:19 PM
Gibson Header Installation? oh4ohyeah Exhaust 7 08-02-2010 10:02 PM
