Old 10-24-2011, 05:51 PM
downonmonday downonmonday is offline
Vehicle: 2004 Dodge Ram 1500 Hemi Sport
Trim Level: Cloth
Rep:33
downonmonday is on a distinguished road
Default Stock Wheels are cruddy...
What is happening to my stock wheels? I have seen this on some other Dodge Ram 1500's that have the same wheels. Anything I can do to get this fixed? I plan on selling the truck soon and this looks horrible. It all started at the end of this past Spring and it keeps getting worse!
Old 10-24-2011, 06:04 PM
2011lilred's Avatar
2011lilred 2011lilred is offline
Vehicle: 2011 1500 & 2006 2500
Trim Level: Express &ThunderRoad
Color: Flame Red & White
Rep:15
2011lilred is on a distinguished road
2004, so those are polished instead of the chrome clad ones, right? Looks like they just need polished...some Mother's Mag and Aluminum polish ought to clear that acne right up.
RIP - 03 Hemi SLT QC; uncorrected 14.68 at 90.46 w/ 2.08 60ft - stolen July 06
Old 10-24-2011, 06:05 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I have a small area of that, but nothing near that bad.
Dillon-aka, The Little Kid
Old 10-24-2011, 06:24 PM
Trim Level: Cloth
Rep:33
It has some sort of clear, plastic like, covering that is flaking and allowing the corrosion.
Old 10-24-2011, 06:32 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Clear coat is peeling, will have to get them repaired at a wheel repair shop.
Old 10-24-2011, 06:34 PM
Trim Level: Cloth
Rep:33
I'll have to call around and see what an estimate is?
Old 10-25-2011, 12:02 PM
goingcrazy goingcrazy is offline
Trim Level: sport
goingcrazy is on a distinguished road
Couldn't the clear be stripped off and the wheels polished and then taken to a paint shop to have some clear sprayed or would that be more work then sending them out to a wheel repair shop?
Old 10-25-2011, 05:21 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I agree with Stainless...the clearcoat is peeling off. I don't think what you are seeing is actually damage to the wheel but rather old, oxidized clearcoat that has changed color. I bet if you start picking at it you could flake it off wherever it is oxidized like that. If you can peel it all off up to the point where the discoloration stops it still won't look perfect but it will look better than it does now.
Theoretically if you could get the clear off you could polish the bare aluminum wheels to remove any surface defects and then wax them on a regular basis and they would be fine. Bare polished aluminum looks just as good if not better than cleared polished aluminum. Problem would be finding the right chemical to take the still adhering clear off without damaging the aluminum underneath.
Old 10-25-2011, 06:59 PM
Trim Level: Cloth
Rep:33
I took some 600 grit, WD40, and mother's aluminum polish to one of the wheels tonight. It cleaned it up and tomorrow I'm going to clear the one wheel. I'll post pics once it's done. It doesn't look 100%, but it's FAR better.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Is tire width the issue on stock wheels? Mudder Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 09-14-2011 05:34 PM
2007 stock 20" wheels but... KestrylX Dodge Ram Wheels And Tires 1 08-04-2011 11:03 PM
New Wheels? Nine8SST Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 12 07-29-2011 03:26 PM
305/70/16 on stock wheels yosemite1977 Dodge Ram Wheels And Tires 0 11-11-2009 08:47 PM
