Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 10-24-2011, 08:12 PM
Culli Culli is offline
Vehicle: 1998 dodge ram 2500
Culli is on a distinguished road
Default stuck rear drivers door
Hello.
the truck is actually my dads, but the bottom latch on the rear passenger door won't disengage. I had the door tore apart and tried everything I could think of to get it open. I even took the rear passenger door apart and pulled out the latch to see how everything works, and still didn't have any luck. Really stuck on this, could use a trick of the trade on this one.
Thanks in advance.
Old 10-24-2011, 10:03 PM
Rutger34's Avatar
Rutger34 Rutger34 is offline
Vehicle: 2011 Dodge Ram 1500 Sport Crew
Color: Pearl Black
Rep:28
Rutger34 is on a distinguished road
If I am reading this correctly, I believe that if you pull the outside door handle and hold it in the open position and at the same time, use a screw driver to flip the latch to the open position.
If this is not what you men, please disregard.........
Injen Power Flow cold air, Truxedo tonneau cover, 3" carbon fiber antenna, Power locking tailgate, tinted front windows. Mopar sidesteps. 3M covering nose. Billet license plate cover, Blue LED interior lights, fully de badged, EZ down tail gate.
Old 10-25-2011, 02:23 AM
Rep:2705
Hold the handle in the open position & a well placed heel kick may be needed if that doesn't work
Then lube everything & check the hinge pins, they may be worn out
Old 10-27-2011, 03:34 PM
thanks for the replies,
the problem is the latch on the underside of the door wont release. Ive given quite a few good heel kicks and once aggravation set in I shoulder checked it pretty good. I also tried using prybars to pry it open with no luck. When I pulled the working one out I messed with it and figured out how to wedge a screwdriver in and release the latch manually, but cant do it on the stuck door because there is not enough room.
Talking to my dad about it more, I found out that it worked perfectly one day and after he had a blow out it stopped working. so guess something inside the latch itself bent and isnt allowing the lever to release it.
As of now, the best I can think of to get it open to fix it is to cuz the bar the latch grabs with a sawzall and just replace both, but even cutting it would be a pain because of the lack of space.
Old 10-27-2011, 10:19 PM
Rutger34's Avatar
Color: Pearl Black
Rep:28
Sorry that I couldn't help. I know that some of the guys in my shop have some "tricks". I will see if there is something else that I can come up with.
rear door locks won't work with fob or drivers door panel switch. charcoal5.9ram Body & Interior 2 10-03-2011 11:11 AM
Trying to find info on my truck snrusnak 2010 Dodge Ram Forum 20 05-24-2011 09:02 PM
Left rear door wont open!?! 01DodgeRam1500 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 10 09-04-2010 12:01 PM
Rear door Panels mlrtym Body & Interior 4 08-21-2010 02:18 PM
wind noise coming from drivers door nocashfortruck Body & Interior 7 04-17-2010 11:20 AM
