Old 10-24-2011, 09:51 PM
extramile's Avatar
extramile extramile is offline
Vehicle: 2011 Ram 1500 4wd Crew
extramile is on a distinguished road
Default Tape Between Doors
Just traded my 09 for a 011 and I have seen some of you guys take the black tape off between the doors. My new one is white and I think it would look good with that black removed between the doors. Can anyone tell me how its done or do you just tear it off................hope mine is painted underneath
Old 10-24-2011, 09:54 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
it does just pull off, do it slowly. my truck is black so I don't have the tape but I took my father in laws off for him his truck is silver and it looks so much better..
please remember to wax the area when you are done. also search B pillar tape removal in the search tool it will show some that have been done.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 10-24-2011, 10:01 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I started at the top and pulled down and toward the window. That seamed Be the easiest for me. I then used 3m adhesive cleaner and cleaned the area. I then waxed the area the adhesive cleaner was on. I think it looks much better. Ps. I tried to pull up and I tried to peel the sides. It was by far the easiest to start at the top corned and pull down and toward the window.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 10-24-2011, 11:02 PM
WhenInDoubt101 WhenInDoubt101 is offline
Vehicle: 2011 Ram Bighorn 4X4
WhenInDoubt101 is on a distinguished road
Anyone have photos?
Just Me.
Old 10-24-2011, 11:26 PM
js1977's Avatar
js1977 js1977 is offline
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
All you need is arm strength, phillips screw driver, goo gone, and a rag. Just open both doors and look at the base of both B pillars. There is a rubber/plastic piece that run along the window. Were the B pillars meet this piece there is one screw holding the trim piece up against the B piller (screw is on the inside of the door). Take the screw out so when you start to peel the tape down, you'll be able to remove it once you get down to the base.
Once the tape is remover, re-install the screw, then spray the glue with Goo Gone. Let it set for maybe a minute and then just rub off until clean. Your done, hope this helped some...
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 10-25-2011, 12:19 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
I have a white sport 10 model and stripped mine off a couple of weeks ago. I tried the first one without any heat and it came off just fine but left a ton of the adhesive. For the rest I used a heat gun to warm it up which made it come off really easy. It also took most of the adhesive with it so there was less to clean. Surprisingly, the adhesive that is left behind does come off easily though. A little Goo Gone and perfect.
You will HAVE to wax it after though. I had kind of a honey comb haze of a pattern left by the tape. A little rubbing compound/wax and it was gone though.
After taking it off, I am really not sure I like it better with it off though. I think it looks a little sportier with it on. Looks more Big truckish with it off. If that even makes sense.... The quad cab look is much more defined with it off.
If i can kill it with an arrow, I'll eat it.
Old 10-25-2011, 08:28 AM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
The link below is a write-up I did on removing the pillar tape.
http://www.ramforumz.com/showthread.php?t=83110
And this thread is for debadging but it has pics that will show you what a white truck looks like with the tape removed.
http://www.ramforumz.com/showthread.php?t=86530
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 10-25-2011, 09:20 AM
RLHOK RLHOK is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Trim Level: Bighorn
Rep:26
RLHOK is on a distinguished road
I removed my B pillar tape with no problem and no residue at all. Stuff just came right off.
Old 10-25-2011, 09:31 AM
jdubsss's Avatar
jdubsss jdubsss is offline
Rep:112
jdubsss will become famous soon enoughjdubsss will become famous soon enough
pics for a white truck are in my thread...makes it look 10x better IMO
Mods: 14" Magnaflow Muffler, AirRaid CAI, Recon Smoked LED Tails, Recon Smoked LED 3rd Brake, Recon White Lightning, 6k HID Fogs, White LED Plate Lights, LED Interior Lights, EZ Down Tailgate, 20% Tints, Pillar Tape Removed, Stubby Antenna
PICS: http://www.ramforumz.com/showthread.php?t=87696
Old 10-25-2011, 10:05 AM
shepcam shepcam is offline
Vehicle: 2013 CC Sport 4x2
shepcam is on a distinguished road
Do it! Its really easy and looks great!
Wtf! Tape!! Canuk1500 Dodge Ram General Discussion 11 09-12-2011 01:05 PM
Couple New Mods - Tails and Pillar Tape Removal(Pics and Video) jdubsss Dodge Ram Pictures - Photos 24 07-21-2011 01:08 AM
How to Use Chrome Tape to Add Some Bling MoparJoe Dodge Ram Knowledge Base 3 02-02-2010 08:01 AM
New here an got a question bout my doors? dirty97ram Newbie Checkin! 10 01-29-2010 05:35 PM
Remote not unlocking doors? Big Daddy 2009 Dodge Ram Forum 5 01-26-2010 07:32 PM
