Old 10-25-2011, 06:38 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Default Questions about wheels
First off, where are some of the better places to buy wheels online? Preferably somewhere that tells the weight of the wheels without calling them.
Second, what is the smallest diameter wheel I can run? I'm assuming 17s is the smallest that will clear the calipers. Also, does anyone know off hand what the backspacing and bolt pattern is on the 09+ Rams? And will all 1994 and up Ram wheels interchange?
Third, I would like to have a set of Ram SST wheels to use at the track. Anyone know where I can find reproductions? The real things are kinda rare.
Finally, does anyone have any recomendations for a set of track wheels if the SSTs don't work out? Lightweight is the biggest concern, looks second. I plan to mount 28 inch ET Streets on them. Thanks guys.
2013 F-150 King Ranch 4wd 5.0
Old 10-26-2011, 01:25 PM
BigWheels.net might be a good site for you to check out.
Also, if you decide on a set of wheels, most mfgr have an email link so you can send an inquiry about the weight if it's not posted there.
17" is as small as I would go on the truck.
I don't believe the R/T wheels have a different bolt circle than the other trucks... 5 X 5.5", 4.5" backspace.
I have not seen any SS/T repros out there but then again I haven't looked.
Obviously, the lightest wheel you can find is your best bet. Look for a forged aluminum wheel, which are the lightest and strongest out there. Weld, Centerline, Cragar, Enkei and USW might be some good ones to check out.
Chrome Clad OEM wheels harleysarge Dodge Ram Wheels And Tires 8 11-17-2013 08:13 PM
20" Alloy Wheels for Sale harleysarge Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 8 11-23-2010 05:48 PM
20 inch to 17 inch wheels ???? 07STMPULR Dodge Ram Wheels And Tires 8 11-10-2010 09:01 PM
Lug Nuts for Chrome Clad Wheels same as the other wheels? Chas4273 Dodge Ram Wheels And Tires 1 11-05-2009 12:18 AM
Couple questions Quiet Lunatic Electrical 4 09-11-2008 07:45 AM
