Dodge Ram Decals
Old 10-25-2011, 11:53 PM
New2Ram's Avatar
New2Ram New2Ram is offline
Vehicle: 2007 Dodge Charger R/T
Trim Level: R/T
Color: marine blue
Rep:22
New2Ram is on a distinguished road
Default Dimming headlights with amp
Ok, I know why the lights dim when my amp pushes hard, but it is only a 200w rms amplifier, I am using 4gage power wire. But when the headlights are on, they dim really bad. Is the altenator on the 4th gen really that weak? Had same amp in my 07 chevy and no dimming. Do I need a capacitor to prevent the dimming? I am concerned that over time it will damage the altenator, and who wants to pay for one of those. I am sure the dealer would void the warranty on the altenator with an amp wired to the system.
Mopar Nerf Bars, 3.55 gears, 20% tint, 18" Magnaflow muffler, shorty antenna, 10" Memphis sub, Sound stream amp, AFE stage 2 cold air intake, tri-fold soft tonneau cover, smoke head light and tail light covers, blue l.e.d. brow lights, Built 12-6-10 @ noon
Old 10-26-2011, 01:11 AM
mtnbkr123 mtnbkr123 is offline
Vehicle: 2011
mtnbkr123 is on a distinguished road
Holy crap. I'm about to put 2400 watts in. I was kinda counting on the Big 3.
Old 10-27-2011, 08:20 AM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
I have a 500 watt rms alpine in my 2009, its the same dimming of the lights, just order a 1400rms amp so the big 3 upgrade is deff a must imo, im ordering a yellow top battery to start with first.............As far as caps go, there was a good write up here someplace about how caps are crap and literally do nothing or something like that
Old 10-27-2011, 05:13 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Yeah that definatly shoulndt happen! I have 500 rms in my 2001 and it doesnt dim that much! Im moving up to about a 1000rms soon and the big 3.
Carven exhaust, K&N CAI, Leveled with wheels and tires, Sundown & Skar audio.
Old 10-27-2011, 06:13 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You need to buy a capacitor! Every amp should have a capacitor! 1 Farad will do the trick....And the lack of one will trash the battery faster than the alternator
Old 10-27-2011, 08:10 PM
voodoochi1d's Avatar
voodoochi1d voodoochi1d is offline
Vehicle: 2009 Dodge ram 1500 slt
Color: silver
voodoochi1d is on a distinguished road
I have 09 and have upgraded cables to battery and alternator and grounds to 0 gauge. I will be installing 2 RF amps next weekend totaling 1100 watts.
I am not installing a CAP, and have not upgraded battery. i will be using 4 gauge cable to power amps.
Will let everyone know what i get then, but would like to hear from other 4th Gens.
Old 10-27-2011, 08:53 PM
Rep:3322
I don't think it's an issue with the alternator or the amp, but if a 200W rms amp is causing lights to dim I'd look at how it's wired up because as most have said, having the higher than average stereos cause this problem.
I hate the ideas of capacitors in most systems as they are generally a quick fix and don't solve the real problem of the battery not passing enough voltage on the deep hits; but in your case this would actually be the most viable solution. I personally would try a different battery first and see if that makes a difference, but adding a cap (I wouldn't go less than 2 farad myself) might be the simple solution for handling the voltage requirements of your amp, and the alternator will easily be able to keep the cap charged if the draw is only 200W rms. If you have a very inefficient amp then it could be causing some troubles as well by maxing the voltage continuously to keep your sub pushing, and that will decrease the life of both the amp and the sub.
Old 10-27-2011, 09:21 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I'm pushing 500watts RMS and have tons of extra lighting and have no dimming whatsoever. I would just upgrade your battery and that should work.
Dillon-aka, The Little Kid
Old 10-27-2011, 09:37 PM
Color: silver
4th gens have 160 Amp alt, what alt does your 05 SLT have Dillon?
Old 10-27-2011, 09:49 PM
Rep:3322
Dillon and I are stuck with the stock 130-135amp alternator. But I'm actually in the same boat as him; my system maxes at 2100W and RMS is around 1800W and all I've done is upgrade the battery to a yellow top with the stock alt. I have zero dimming issues when I run my HIDs, grille lights, all my LED lighting, and stereo, even at idle.
I'm not 100%, but I believe the 4th gens have the same amperage regulating system as the LX platform and even if you upgrade the alternator, the system will regulate the amperage unless you obtain an alt from one of the FEW places that have found a way to bypass this system.
Suggestions for aiming projector headlights Riggz13 Custom Dodge Ram Interior and Exterior Lighting 2 08-22-2011 10:17 PM
headlights 00sport Custom Dodge Ram Interior and Exterior Lighting 7 02-03-2011 01:24 AM
New 2010 Dodge Ram. Headlights suc$! bikewv Electrical 16 09-01-2010 01:15 PM
1994 Ram 1500 Headlights out rcarmel Electrical 3 04-28-2010 09:39 AM
The difference between ram headlights and sport model headlights yosemite1977 LD RAM - General Discussion 5 10-02-2009 03:47 PM
