Old 10-28-2011, 12:38 AM
New2Ram's Avatar
New2Ram New2Ram is offline
Vehicle: 2007 Dodge Charger R/T
Trim Level: R/T
Color: marine blue
Rep:22
New2Ram is on a distinguished road
Thanks for the replies guys. May be a dumb question, but what is "the big 3"? And my amp is older, probably an early 2000's Soundstream amp. So it may be inefficient when compared to brand new ones. I have a 4ohm dvc sub wired to 2 ohm. It is a brand new memphis sub. Not trying to blow the niebors ear drums, just add some depth to the music. And the lights don't dim excessively, just enough to notice when driving down the highway at night. I have the power wire (4 ga)run from + on bat thru a 100amp fuse, then to amp. Ground wire may be the culprit, prob only 12ga maybe. It is only 10"-12" long. This is about the only thing that I can think of. Dont want to fork out $ for a different battery...
Mopar Nerf Bars, 3.55 gears, 20% tint, 18" Magnaflow muffler, shorty antenna, 10" Memphis sub, Sound stream amp, AFE stage 2 cold air intake, tri-fold soft tonneau cover, smoke head light and tail light covers, blue l.e.d. brow lights, Built 12-6-10 @ noon
Old 10-28-2011, 12:51 AM
voodoochi1d's Avatar
voodoochi1d voodoochi1d is offline
Vehicle: 2009 Dodge ram 1500 slt
Color: silver
voodoochi1d is on a distinguished road
your ground should be at least 8 gauge, and make sure its grounded to unpainted metal surface of your truck body.
That could very well cause power issues. not sure if dimming lights would be what you would notice however.
the soundstream amp is 200w? that Memphis sub, shouldnt you be putting more like 500w to it? too little power can damage a speaker is what i was always told.
Old 10-28-2011, 11:26 PM
I push the skinny pedal
Rep:3308
I've never heard of too little power damaging an sub, but that's not saying it's not true in some respect. If you're not pushing enough power to the sub, it's like trying to push your truck up a slope by yourself, it may eventually get there, but it won't be fast or pretty. I would agree that if your power wire is 4ga, then your power wire should be minimum of 8ga, but I'm a firm believer in power in = power out, so the ground should be the same as the power wire.
The big 3 is an upgrade to your stock power supply system. You replace the alt - fuse box, fuse box - +battery, and -battery - ground. This allows maximum current to pass from the alt through every device and return to the battery. It's important to put a fuse in the alt-fuse box line as you are removing the OEM fusable link.
I personally upgraded all my grounding on the block and tranny as well to 4ga to combat some of the alternator whine. I also did my Big 3 with 1/0 as I had 4ft left over from my install. It definately made a difference in the cranking speed.
Kurtis
Old 10-31-2011, 01:56 PM
Color: silver
I have noticed an increase in cranking speed, but have noticed that my voltage gauge needle has moved about 1/4" higher. its almost halway between the 1/2 mark and the 3/4 mark on the gauge.
Old 11-01-2011, 05:47 AM
alaskangiles alaskangiles is offline
Vehicle: 2008 Ram 2500 Hemi
Trim Level: TRX4
Color: Grey
alaskangiles is on a distinguished road
I'm having this same issue. 1000 watts rms, dual red tops, 200 amp mean green, 1/0 cable jumped from alternator to battery, and 1/0 main ground. And if I'm just being strait rude my HID's will turn off, thats how bad mine is dimming. I'm at a total loss of where to begin now? Tear it all out or just let it smolder to the ground, not a good time right now with this thing.... To much time and money
Old 11-01-2011, 02:55 PM
mtnbkr123 mtnbkr123 is offline
Vehicle: 2011
mtnbkr123 is on a distinguished road
Originally Posted by alaskangiles View Post
...And if I'm just being strait rude ...
Haha!
I am surprised 1000 watts RMS is causing problems. Shocked actually. Especially with the jacked up alternator and 2 red tops. That said, not sure about the red tops. I suspect 1 higher end Shuriken or Kinetic might be a much better bet. Nonetheless, wow. What kind of amp(s) are you running? Newer Class Ds? Are you confident your alternator is an honest 200 amps? Are you confident your Big "2" is hooked up properly? Maybe complete it for the Big 3?
Old 11-01-2011, 04:29 PM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
I would deff test that alternator output, then make sure you wires are nice and tight, then look at the amp.....Do you have a friend or anyone that has a 1k amp and swap them out and see if it does the same thing?
Old 11-01-2011, 05:07 PM
Trim Level: TRX4
Color: Grey
PDX-M12 Mono Power Amplifier
- CEA-2006 Power Ratings:
1200W RMS x 1 [4 ohm @ 14.4V ≤ 0.04% THD+N]
S/N: >92 dB @ 1W/4ohm
Availability – Now
We swapped it out for a new one thinking it was the amp itself, no such luck.
We got a new alternator, hints the Mean Green.
http://shop.mean-green.com/2010-07-R...MI-MG1390A.htm
Upgraded the cables and ran a second battery and still the same.
Old 11-01-2011, 05:42 PM
Vehicle: 2011
Availability – Now
Holy crap. That's a brand new, Class D, decently efficient amp - the fuse in it is 120 amps. I am so screwed if I ever get around to getting my system installed. Maybe it's a blessing in disguise that I've been delayed. At least my truck runs.
Old 11-01-2011, 10:43 PM
Trim Level: TRX4
Color: Grey
So I'm missing the fuze box? Then "the big three" will be complete? What is the 1/0 cable I put strait from the alternator to the battery doing then?
Sorry to steal your thread man, but it sounds like we both might find a solution.
Suggestions for aiming projector headlights Riggz13 Custom Dodge Ram Interior and Exterior Lighting 2 08-22-2011 11:17 PM
headlights 00sport Custom Dodge Ram Interior and Exterior Lighting 7 02-03-2011 01:24 AM
New 2010 Dodge Ram. Headlights suc$! bikewv Electrical 16 09-01-2010 02:15 PM
1994 Ram 1500 Headlights out rcarmel Electrical 3 04-28-2010 10:39 AM
The difference between ram headlights and sport model headlights yosemite1977 Dodge Ram General Discussion 5 10-02-2009 04:47 PM
