Old 11-01-2011, 11:31 PM
New2Ram's Avatar
New2Ram New2Ram is offline
Vehicle: 2007 Dodge Charger R/T
Trim Level: R/T
Color: marine blue
Rep:22
New2Ram is on a distinguished road
Originally Posted by voodoochi1d View Post
your ground should be at least 8 gauge, and make sure its grounded to unpainted metal surface of your truck body.
That could very well cause power issues. not sure if dimming lights would be what you would notice however.
the soundstream amp is 200w? that Memphis sub, shouldnt you be putting more like 500w to it? too little power can damage a speaker is what i was always told.
The sub is an 'S Class' sub with a rms of 300w and peak 600w, so I am not underpowering it by much. I am going to upgrade to a newer amp sometime because after my wife hearing my truck she wants me to upgrade the system in her car So this amp will go in the car because she won't listen to it as loud as I do. Memphis has a matching amp to this sub with a rms @2ohms of 300w. I dont think it will be a problem in her car because I will put it on a 4 ohm 12" JLwo 125w rms that I have. Amp puts out 100W @ 4omhs. And don't worry about thread-jacking... I'm learning lots!
Mopar Nerf Bars, 3.55 gears, 20% tint, 18" Magnaflow muffler, shorty antenna, 10" Memphis sub, Sound stream amp, AFE stage 2 cold air intake, tri-fold soft tonneau cover, smoke head light and tail light covers, blue l.e.d. brow lights, Built 12-6-10 @ noon
Old 11-01-2011, 11:46 PM
mtnbkr123 mtnbkr123 is offline
Vehicle: 2011
mtnbkr123 is on a distinguished road
Originally Posted by alaskangiles View Post
So I'm missing the fuze box? Then "the big three" will be complete? What is the 1/0 cable I put strait from the alternator to the battery doing then?
Sorry to steal your thread man, but it sounds like we both might find a solution.
The Big 3 is: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. I'm not sure what you've done. It sounds like you've done 1) but I'm not sure about 2) and 3).
The 120 amp fuse has nothing to do with that. I only raised it as an indicator of how much power the M12 draws.
I could be wrong but I am quite sure that lots of people are running much more power than 1200 watts without even having done the Big 3, with no problem. I hope to be able to soon speak from experience - 2400 watts as soon as I can get some time to get it done. I did work on my amp rack tonight though, so that's a start.
Old 11-02-2011, 02:32 AM
alaskangiles alaskangiles is offline
Vehicle: 2008 Ram 2500 Hemi
Trim Level: TRX4
Color: Grey
alaskangiles is on a distinguished road
DING DING DING DING DING!!!!!! Engine to frame, never even thought of that. Let's hope it's that simple. I'll report back in a few hours. THANKS!!!!
Old 11-02-2011, 10:47 PM
Tuckert's Avatar
Tuckert Tuckert is offline
Vehicle: 2006 Ram 2500
Tuckert is on a distinguished road
Alright I don't want to jack the thread, I hope it gets solved, but I have an 06 cummins with a Kicker 650.1 pushing two CVR 10's, my lights don't dim when they hit or anything, but almost always when I start it, it's fine then battery gauge starts falling, head lights, dash lights dim down, then gauge climbs to normal lights back up, then repeat, after a short drive like maybe a full minute it's over, doesn't happen again. just when I start? I have two batteries stock, I'm running off the drivers side one, any ideas?
HD Bumper Rear Bumper Side Steps Headache Rack 2 Kicker CVR10's, Kicker 650.1 Amp, Polkaudio DXi 12
Old 11-02-2011, 11:04 PM
Trim Level: TRX4
Color: Grey
That sounds like a glow plug issue. Never got to mine today.
Old 11-02-2011, 11:48 PM
Tuckert's Avatar
Are you referring to me? The cummins hasn't had glow plugs since I'd say 89?
I have no enigine starting/heating problems it's electrical, my subs stop, battery gauge drops, lights dim, then back up subs start
Old 11-09-2011, 05:11 AM
Trim Level: TRX4
Color: Grey
Yes, I was talking to you. Ok, grid heater issue or othwise known/called glow plugs. I have never owned a Cummins but I lived in one for three years in the Air Force. Everytime those "grid heaters" would cycle it would just about shut off the lights. At -40* it wasn't even worth driving. Then I used my buddies when he was out of town and it didn't do it so bad. Both 98.5' trucks. I took it in to the motor pool and it came back fixed.
Old 11-09-2011, 10:10 PM
Tuckert's Avatar
Alright, I'll check it out, and yeah glow plugs lol grid heater
Old 11-14-2011, 05:46 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Caps are craaaap ... i run 2000 watts only have light dimming at high levels. I use an yellow top 0 gauge wire and have soldered grounds. A bad ground is likely your problem 200rms shouldnt dim your lights. I plan on the big 3 in the spring, and if that doesnt work a possible upgrade in the alternator to a high out put.
Old 11-16-2011, 03:24 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2011 Ram Express
Rep:92
Graygoose will become famous soon enough
Forget caps. If you wonder why it may dim, look at power wire to amp, and ground. Check voltage at the amp when it's hammering. See what the voltage is.
Underpowering never hurts speakers, distortion does, because most use the gain knob as a "power" knob. Too much gain, equals distortion, hence clipping, bad power, blown speaker.
2011 White Ram Express, Custom American Racing 2-piece forged, Nitto 420s 22's,Extang Trifecta, Belltech 2/4 drop, Magnaflow catback,KICKER sound system,CodeAlarm remote start, '13 Retroshop Headlights and Tail lights, Bedrug, Custom MGP Caliper covers, LED reverse lights, AAC interior LED and licence plate LEDs, BT Catch Can,Weathertech mats
Suggestions for aiming projector headlights Riggz13 Custom Dodge Ram Interior and Exterior Lighting 2 08-22-2011 10:17 PM
headlights 00sport Custom Dodge Ram Interior and Exterior Lighting 7 02-03-2011 12:24 AM
New 2010 Dodge Ram. Headlights suc$! bikewv Electrical 16 09-01-2010 01:15 PM
1994 Ram 1500 Headlights out rcarmel Electrical 3 04-28-2010 09:39 AM
The difference between ram headlights and sport model headlights yosemite1977 Dodge Ram General Discussion 5 10-02-2009 03:47 PM
