Old 10-26-2011, 10:59 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
I would like to go 38's but I am running into width issues
Old 10-26-2011, 11:05 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
For the overall width of the tire 14.5" is the absolute max with 4.5" bs. A guy running 37x13.50 mud graps are 14.3" wide and is DARN close to rubbing on the knucke!
What tire you looking at??
[CENTER][SIGPIC][/SIGPIC]
Old 10-27-2011, 09:01 AM
Color: Rugged Brown
Rep:27
well I am currently running 35x12.50 Pro comps which say to be a true 12.50 tire and I cant fit my pinky between the tire and the spindle
Old 10-27-2011, 09:17 AM
candy08's Avatar
Rep:213
Correct me if I'm wrong but it looks like you're running the extreme mud terrain!? With you're 6" lift and adjustable Bilsteisn (what setting you at) you shouldnt have any issues what so ever. You can run a tire up to 14.5" "actual width". I cant find the specs on the pro comp, but I'm guessing you have a 5" backspacing on the wheels if you have issues...
Old 10-27-2011, 12:37 PM
Taylor15835's Avatar
Taylor15835 Taylor15835 is offline
Vehicle: 2010 ram 1500 sport
Trim Level: sport
Taylor15835 is on a distinguished road
The pro comp lift tells you the max an min offset, at first i had fuel gauge wheels that were in the middle of the two number srry i can't tell you what the offset was I'm not so good with wheels, but with a 12.5 nitto they almost rubbed the knuckle, but i ended up swapping them out for xd wheels the were 1 inch more of an offset an not theres a hell of a lot more room for width.
Old 10-27-2011, 12:55 PM
candy08's Avatar
Rep:213
I can tell you off the top of my head that pc calls for 4.5"-5" backspacing. Thats why i was guessing you had 5". To clear anything somewhat wide, 4.5" bs is the only way to go!
Old 10-27-2011, 02:36 PM
Color: Rugged Brown
Rep:27
yep wheel back spacing is my problem.no idea what the spacing is as they were on the truck when I bought it. Also not sure on the setting for the front but it is def. not a height issue and the truck sets almost exactly level. I need new wheels but I hate to spend the money. They are pro comp wheels also.
Old 11-12-2011, 12:10 AM
DVSk8er DVSk8er is offline
Vehicle: 2010 Dodoge Ram 1500
Color: Inferno Red
DVSk8er is on a distinguished road
with 38's watch the width. i have 38x15.5's on my truck with 6" skyjacker, bilsteins up front and 1.25 body lift. and i get minor rubbing on the plastic fender well. and i have 18x10's with -24mm offset
Bilstein 5100 with 6" Suspension Lift Question BJPUSMC Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 13 06-08-2015 12:29 PM
My 1st post... Looking for a 6" lift plz help me GetItBig Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 08-25-2011 08:45 PM
2011 1500 SLT 4 X 4 Lift toothpick Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 31 05-12-2011 04:40 PM
3" torsion key lift + 6" susp lift?? MoparerNocar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 05-05-2010 11:33 PM
