Old 10-26-2011, 07:51 AM
gingersport's Avatar
gingersport gingersport is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Sport 4x4
Color: Deep Cherry Red
gingersport is on a distinguished road
Default Bilstein and Wheel Help!
I plan on leveling my baby with a set of 5100's and throwing some new wheels and tires on it in the near future. I was just curious if anyone knew if 20x10 with a -24 offset would work? If so, would I be able to 35-13.50 tires or am I just getting to greedy? The wheels I want are offered as follows:
20x10 -24 4.5" backspace
20x10 -12 5"
20x9 -12 4.5"
20x9 0 5"
Any help is appreciated. This is my first vehicle worth customizing, and I'd like to do it right.
Old 10-26-2011, 08:14 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Your specs don't look correct. A higher offset number should have less backspace (a -12 should have less backspace than a -24). Might check those numbers.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 10-26-2011, 08:20 AM
They are Fuel Hostage wheels. The numbers I listed are the ones they show. The whole offset backspace thing kinda confuses me. Id rather ask for help than get it wrong.
Old 10-26-2011, 08:43 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
You should be fine with a 20x10 and -24 offset aka 4.5" backspacing. I'm running those same wheels and specs
[CENTER][SIGPIC][/SIGPIC]
Old 10-26-2011, 02:46 PM
Ok, thank you Candy08. I see that you're running 37's with nine inches of lift. Do you think 35-12.50's would clear with just the leveling kit?
Old 10-26-2011, 03:38 PM
candy08's Avatar
Rep:213
Maxed bilstiens and prolly a little spacer for the rear....I bet you could.....
Old 10-27-2011, 09:21 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Former, I think you may be mistaken. A higher offset number should have more backspacing that a lower one. Example....say you have four rims of equal width in various backspacing (-24, -12, +12, +24). The -24 would have the least amount of BS and the +24 would have the most BS.
Gingersport, offset and BS is relatively easy once you get a handle on it. Offset is the measurement in millimeters from the wheel mounting suface (the flat area on the back of the wheel that mates up with your hub) to the center of the wheel's width. BS is the measurement in inches from the same wheel mounting surface to the rear edge of the rim. That being the case, obviously, changing offset has a direct effect on the BS of a rim. Zero offset means the mounting surface is right in the middle of the wheel. Positive offset means the mounting surface is on the front half of the wheel and more wheel is tucking back toward the vehicle than is sticking out. This type of wheel also will have more BS than a zero offset or negative offset wheel. Negative offset means the wheel mounting surface is on the back half of the wheel and more wheel is sticking out from under the fender than tucking under. Negative offset wheels have less BS than zero offset or positive offset wheels. Here is a good visual.
All that being said, I think you should be able to run 35x12.50s with some Bilstein 5100s and you MAY be able to run the 20x10 with -24 offset (I really don't know for certain) but even if you can it is going to stick out from under the fender a lot....atleast a couple of inches more than stock I would say.
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 09:37 PM
Bilstein 5100 leveling kit causing vibration? akt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 05-29-2011 08:20 AM
Bilstein 5100's on 4x2 bighorn10 2010 Dodge Ram Forum 11 03-29-2011 12:08 AM
Bilstein 5100 4wd Shake medicnorth Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 10-09-2010 07:50 AM
Bilstein 5100 Leveling Shocks Question - 2010 Ram 4x4 FormerGorilla Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 09-28-2010 01:24 AM
