Old 10-26-2011, 12:31 PM
clemclark clemclark is offline
Vehicle: 1999 dodge ram
Trim Level: sport
Color: sport
clemclark is on a distinguished road
Default help
ok getting no bus read out on my 99 dodge ram any ideas change all intake gaskets and now this problem any sugesstions
Old 10-26-2011, 12:54 PM
2SSick's Avatar
2SSick 2SSick is offline
Vehicle: 2001 Dodge Ram Sport
Trim Level: 1500 Extended Cab
Rep:20
2SSick is on a distinguished road
No bus readout?
Nvm...just did a little google search and found this...i dont think it has anything to do with your intake gasket replacement unless you moved some wires the wrong way in the process...check it out.
http://***************/forum/1st-gen...ng-no-bus.html
Where the **********'s are just replace them with
dodge forum . Com (no spaces) its kept starring out the forum name...idk
Old 10-26-2011, 01:44 PM
Make sure you didn't unplug your PCM and that all main connections to the battery, ground and starter are clean and tight.
Old 10-26-2011, 03:38 PM
Trim Level: sport
Color: sport
i notice that if run jumper ground to ground on pcm light on hood gets brighter but wont crank over unless being jump but even then just dies out
